Old 02-14-2023, 01:50 PM
sorner's Avatar
sorner sorner is offline
I pulled it all apart to check it out more, we haven’t had any snow to run it in yet. The idler was indeed on backwards with the spacer in the front. I switched it around and it’s aligned better. It’s not perfect but better. I feel like the belt is a little too big, because the idler is almost right against the pulley. If it stretches at all they’ll be rubbing. I got the size it calls for on cubfaq, so I always seem to have belt size issues. Even my pants won’t stay up!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 02-14-2023, 04:30 PM
Are you using the #954-0154 (1/2" x 37") Belt ??
Old 02-14-2023, 04:51 PM
sorner's Avatar
I have a 5L410.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 02-14-2023, 05:55 PM
Originally Posted by sorner View Post
I have a 5L410.
a 5L410 measures 5/8" wide by 41"
"L" series belts measure what the numbers state, in this case 41"
The equivalent of a 1/2x 37 would be 4L370
If your pulley's accept a 5/8" wide belt, go with a 5L400 or in a traditional belt,
a B-37 which measures 5/8 wide by 40"
Yes it is confusing, but not if you understand how they are measured/classified.
Old 02-14-2023, 06:30 PM
sorner's Avatar
I get mixed up on the ID and OD measurements. I guess I need another belt.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 02-14-2023, 06:48 PM
A "Section A" belt is more heavy duty than a 4L belt. With that in mind, I would use a A35 Belt.
Old 02-14-2023, 07:02 PM
sorner's Avatar
Wait a minute, this takes a 1/2” belt?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 02-14-2023, 07:45 PM
It ALWAYS pays to look up and use the correct parts.
Old 02-14-2023, 07:59 PM
sorner's Avatar
So here’s my confusion… Cubfaq.com says 954-0284, which looks like a 5/8-41, which is where I got the 5L410 from. 954-0154 is for 800 - 1650, 1100 isn’t it? This is going on my 1912.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 02-15-2023, 06:18 AM
Nothing is better than the original Cub Cadet Parts & Service Lookup tab, as seen at the top of the page.
Tags
364
