Old 02-14-2023, 10:43 AM
wilypence wilypence is offline
Originally Posted by BKsCC View Post
There's this stuff called Evap-O-Rust that's about $25-$30 for a gallon at tractor supply. It's really good stuff and works better and faster than vinegar, and won't accidentally discolor metal red from sitting too long (It'll darken metal though if it sits for over 24 hours). I just used it to do my tank. It's reusable for several uses so don't just dump it away when you're done. Run it through some cheesecloth to catch the chunks of rust and then re-bottle it.
I have also used this with great success. I have been using the same gallon container of Evap-O-Rust for over 10 years now. If there's flaky rust in the tank I let it sit for a day or so, turning it every few hours to make sure all surfaces get soaked. If it's not bad it may only take an hour or so. Make sure to fill it back with gas fairly quickly because once it's cleaned to bare metal it will flash rust pretty quickly if you let it sit empty.
Old 02-14-2023, 04:46 PM
LAWN BOY's Avatar
LAWN BOY LAWN BOY is offline
Default MMO purchasing
Where can I buy the MMO?
IH Cub Cadet 70 project, view my thread in the Kohler engines section for progress.
Old 02-14-2023, 06:49 PM
Anywhere. Big Box stores, Auto Parts store, Farm/Ag Stores, Hardware stores, even Wal-Mart.
Old 02-14-2023, 07:19 PM
LAWN BOY's Avatar
Default Response to R Bedell
Oh, okay. I’ve never noticed it before in stores. Thanks for letting me know. I’ll look next time I’m in town.
Old 02-15-2023, 06:53 AM
farmer52 farmer52 is offline
32oz bottle at Wally World - $7.48 (1 gallon $21.97). Both are in stock at my local store.
Ken
Old fart - new to Cub Cadets
Looking for a nice original low hour 1772 or 1782
Old 02-15-2023, 09:31 AM
LAWN BOY's Avatar
Default Just checking
I’m just making sure because I’ve never done this before.
Evapo-Rust will not cause flash rust, correct? I know vinegar would.
The DAWN and warm water will not cause flash rust so long as I get the MMO in there after rinsing thoroughly, correct?
Old 02-15-2023, 11:11 AM
ironman's Avatar
ironman ironman is offline
Flash rusting is not caused by vinegar nor Evapo-Rust.
It is caused by humidity (moisture) in the air attacking the newly cleansed ferrous metal of the tank.
MMO to prevent flashing was a suggestion, not a requirement.
Any thin, mild lubricant that you can fully coat the inside of the tank with will suffice,
Something such as transmission fluid or light oil reduced with kerosene.
Then just rinse the tank out with gasolene before using.
