#21
The perforated steel grille insert has been cut out, painted and bolted to the grille shell. I know this early design grille was recalled due to debris clogging the grill, but I like the looks of it. I won't be mowing too much with it, and it will stay clean. Also, here is the material I started with. Was just enough to do this grille and the grille on my 1282.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#22
The upper steering column bushing was worn, so I went with a wheel bearing from a much earlier Cub Cadet with the 3/4" front spindles. IH 384881 R94
#23
Does it seem to steer easier with this bearing in place?
#24
To be honest, it doesn't feel much different in terms of effort, but it is nice and tight without wobble. This will last far longer than the bushing.
#25
Nice upgrade.
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
#26
Now take the steering wheel back off, and install a tie rod boot on the shaft of appropriate size to fit tightly on the shaft, and umbrella the bearing to shed water/debris off it
![]() ------unless you promise yerself, yall will not ever get water/dirt in the bearing
#27
Haha
It's fully greased and that foam "seal" was replaced. This one shouldn't get wet often. The tie rod boot is a great idea.
#28
The original mule drive and deck are installed and working. Both new belts installed.
#29
The presumably original throw-out bearing decided to take a dump, so out came the driveshaft/clutch. The clutch disc was practically brand new, so only a new OEM 703-0600 bearing/sleeve, and 732-3017 teaser spring were installed. Now, the clutch is quiet again. The only issue is that the bearing was made in Chyna, but it was physically larger than the one I removed.
