Old 04-27-2023, 03:04 PM
Just FYI, not all Vanguards have the fuel shut off solenoid. You can simply remove it and replace it with the factory plug or do as I do on all my Vanguards, remove the solenoid, cut the plunger off and then re-install it. If it's not on the engine it can't cause problems.
Old 04-28-2023, 04:50 PM
malibulvr malibulvr is offline
Originally Posted by malibulvr View Post
So I ended up ordering the diode assembly and a new fuse holder, so hopefully this will do it, we will see. Thank you in advance for the time you've taken to help me.
Yes I ordered the diode, and the place sat on it for 3 days, so I called them and they said that it's discontinued and I could not get it. Not sure when they're going to tell me that.
Old 04-29-2023, 06:54 AM
Cut the plunger of the solenoid and be happy
Old 04-29-2023, 08:52 AM
That's why it's hard to beat Amazon.
https://www.amazon.com/HUABAN-1N5391.../dp/B08MDYRLWD
I think the 1.5 amp will work or if you want bigger these are a 5 amp.
https://www.amazon.com/20-Pieces-SR5...NsaWNrPXRydWU=
Old 04-29-2023, 01:25 PM
ironman's Avatar
ironman ironman is offline
If anyone is curious,
I did some bench testing on a briggs carb solenoid.
At 12.5 volts it draws 350 milli-amps (a little over 1/3 amp)
Old 04-30-2023, 02:27 PM
So of course I ended up finding one on Amazon LOL. I ran out to the garage, clip the ends off the old diode, j-hooked the diode and remaining ends so I had a good bond with the solder and retention. Threw some sleeving over it, went out to hook it up and of course the fuse immediately blew.
Then I put a larger amp fuse in it this time, 30 amp and the tractor actually ran for about a minute until it blew.
How do I get the solenoid out of the carburetor?
I must still have a short somewhere, this is getting ridiculous LOL. Could the solenoid itself be grounding out?
Today is not the day to be working on this, since it is outside and of course it's raining today.
Old 04-30-2023, 02:33 PM
So since that diode goes directly to the starter, I'm assuming that once the tractor starts if it was just a wire without a diode it would actually ground out correct? Because I noticed that when I check polarity on the main coming off the solenoid to the starter it shows negative and then changes the positive once the solenoid is activated.
Old 04-30-2023, 04:28 PM
ironman's Avatar
Can't tell from your pictures but the lead on the end of the diode with the silver band around it should go towards the carb.
If that is not the case, the fuse will blow.
Old 04-30-2023, 08:17 PM
Solenoid is on the rear bottom right side of the carb. You should be able to get to it from the top by removing the air cleaner assembly including the base plate. Close the choke to prevent dropping a screw down the carb.
Old 04-30-2023, 10:26 PM
Silver end is opposite the starter
