Old 06-13-2023, 12:01 PM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Originally Posted by knucklebuster283 View Post
I know Battery is good. Was brand new last October.
Just because the battery is "new" or "newish" does not necessarily equate to the battery being "good". I've seen almost brand new batteries fail because of slipshod manufacturing.
If it checks out after a load test, then it is considered good.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 06-13-2023, 09:14 PM
Farmall450's Avatar
Originally Posted by 1711Cub View Post
This is another example of "your results may vary". I have had stellar luck with the Noco unit, and when the light turns green, I move on to the next battery-supervised. I haven't lost one yet.
Ditto. Just topped off the non charging 127 (I'll fix that when it stops raining, maybe ) with the Noco 1.
