Old 07-22-2023, 12:18 PM
Littlejohn Littlejohn is offline
ok, between yesterday and today, i've learned what ever is going on is getting worst, yesterday, tractor would not start, but almost did, today, did not even try. So i went back to the basics:
suck, pump, bang, blow.
Suck: air/fuel: issues won't run to run poorly.
Pump: Compression, issue run poorly
Bang: spark/electrical, issues won't run to run poorly
Blow: exhaust, issues blocked, won't run
now lest remove two
pump and blow: both seems to work just fine.
next is bang.
that seems to work just fine, to day i sprayed a little carb cleaner in carb and got bang, so spark in fine.
that leaves us with suck.
before it was acting like it was getting fuel, a small amount, now it is acting like it's not getting any fuel.
would the best course of action be to take the carb off, take it apart and clean it with ether carb cleaner, MEK (methyl ethly ketone) or acetone (dimethyl ketone)
what do you think
Old 07-22-2023, 01:29 PM
By all means, pick up a carb kit (about $15 or so) and go through the carb.
Should have been one of the 1st things to do with a carb of unknown condition and sitting for a long period of time.
Should be many tutorial threads on here pertaining to how to do that.
This one comes to mind
https://s3.us-east-2.amazonaws.com/c...rb+Rebuild.pdf
Old 07-22-2023, 06:52 PM
jcubtroy's Avatar
jcubtroy jcubtroy is offline
Clean out the tank too & sediment bowl. Electrical, all else fails, run the machine in shop after dark no lights hood up or off, look for sparks.
Old 07-23-2023, 08:32 PM
SDBOB SDBOB is offline
Take hose off of carb let run into empty can to see steady flow. I just had a problem on my 1650. The positive cable copper connector to battery was tight but loose. I pulled it off and found corrosion, so I cleaned it, added electric grease, and recrimped.
Old 07-27-2023, 11:39 AM
Red face
I would like to thank you all for Your help.
turns out the carb was clogged.
now i need to adjust the high speed idle, runs a little ruff.
and the fuel line is interfering with the governor
Tags
electrical problem
