Old 09-18-2010, 02:29 PM
Flatbedford's Avatar
I spent some time on the tank last night. First I poured a couple tablespoons of Simple Green and water into the tank. I put the cap on, plugged the threaded nipple with my finger and shook it for a while. With the garden hose I filled the tank until it overflowed and then let it drain a couple times. When it was full of water I plugged the bottom hole with my finger and watched for leakage. There were a few leaks right where the threaded tube is attached to the flange that is soldered to the tank.
I drained the water and blew air through the tank with the exhaust from my shop vac. After that I piped some exhaust from my '70 F350 (the dirtiest exhaust in the driveway for sure) into the tank. After all that I figured I could work on the tank without much fear of explosion.
With a wire wheel on my Dremel tool I cleaned the area thoroughly. I smeared flux around all the suspect joints and went at it with MAPP torch. I was surprised how much heat I needed to work the silver solder, but I was able to lay a nice bead around the suspect area.
After some cooling time, I chipped the flux off and did some clean up with the Dremel tool again. I filled the tank with some water, plugged the hole with my finger and watched. No leak. After shaking as much water out as I could, I threaded the valve/glass bowl assembly back onto the tank and closed the valve. I put about a cup of gas in the tank and checked for leakage. Still holding. I dumped the water gas mix and refilled the tank with some more gas.
I left it out side over night and there is still no leakage. I guess I have fixed the tank. I still have to get some paint on the tank where the torch burned it off and I will be replacing the valve/glass bowl assembly before I put it back on the tractor.
Looks like I have fixed my leak with minimal expense and without any explosive gas fume mishaps. Thanks to all for your input.
Steve,
Former multiple 149 owner.
Old 09-18-2010, 09:07 PM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
talking of silver solder, my dad worked at westinghouse for 40+ years in the copper shop and over time some of the extra silver solder found its way home here.:biggrin2.gif:
there are 2 main types that i have on hand the first comes in a round rod form and when heated it tends to flow and fill gaps and the second is a squared rod type that you can bild up and fill in with. also have a limited amount of a third version that is a thin paper like wafer, he said when you had 2 large flat surfaces you would lay this between thme and heat it up and when done was welded fully on the inside
Old 09-18-2010, 10:46 PM
johncub7172's Avatar
Default No leak/soider
Here is a pict., I guess I did use white tape....no leaks yet. I forget what soider I used, but it sealed it's own soider weld mud-job. Used regular torch in hand-held bottel. One important factor to preventing a fuel leak as my IH 71 is to make sure the tank is strapped properly and that the saddel cussion is square, and not to over tighten. I used lamp oil wick from a hurricane lamp. Dont over tighten to tannk nipple.
