#21
Good to know Matt, I hadn't even thought about the vibration effects on the drive line. Glad the other diesels rattle like mine at certain throttles. Mine does fine at very low idle just before the off position, and then on up at halfway through full.
#22
For you fuel burners if you want to get around the low sulfer crap they call fuel just buy #2 heating oil from the heating oil guy. You'll also save some money.
#23
When i'm using my diesel around the yard etc... I always make a point to stay away from that one vibration spot with the throttle. Hondo what a great find on that tractor. You'll love it.
#24
Well I have a slight vibration...
Apparently this thing was used without one of those rag joints or flex disc on the drive shaft in the rear and the front one is torn. Can anyone with the same tractor take a picture of the rear drive shaft connection so I can see what parts I need? |
#25
This might help. There's supposed to be 2 flex discs on each end.
#26
Just going to throw my 2 cents in on the warm up issue. While I have never owned a Cub diesel, I will pass this along: I built hydraulic excavators and wheel loaders at Caterpillar for years. It is never recommended that a diesel motor is ever started and ran over idle. The engine will "clear" itself out as it warms up and start to idle smoother. Running over idle at start up risks damaging internal parts.
Eric 1450 in progress.......... |
#27
Is there any easy way to tell the 44A or 50A decks apart from the 44C or 50C decks?
Visual clues? I look at the operator manuals in the other forums and nothing jumped out at me. |
#28
44A/50A have a center pulley for a 3/8" belt, 44C/50C have a 5/8" pulley there. On the bracket welded to the front of the deck where the adjustable front links attach, there are 2 holes for the front links on an "A" deck and 3 on a "C".
#29
Would the mowing decks of either of these two work on mine?
I keep searching but its so darn hard to find model numbers/years etc. for these things. http://dayton.craigslist.org/grd/1973370303.html http://dayton.craigslist.org/grd/1962441545.html |
