Old 03-01-2011, 11:43 PM
westofb's Avatar
westofb westofb is offline
Default exhaust idea?
looking at the longer of the 2 exhaust manifolds/flanges, if you used it it appears that you could point it straight down. If that is infact the case, why not run the exhaust down, turn it along the frame rail and exit out the back of the tractor...kind of like some of the orchard tractors had so the exhaust did not hit the fruit trees? Maybe not such a good idea, heat issues and close clearances...just thinking aloud....
Old 03-02-2011, 12:48 AM
dieseldan123's Avatar
I also had the same idea! But i didnt like the thought of burning up the belt since it was that close to the mule drive. Turns out i was able to save the existing thread on the block itself. Ran a tap the same size diameter and it cleaned up real nice . Used some old piping i found at the correct diameter and cut it to length and mounted my "stack". Still need to brace it somehow but will worry about it after i can get it running. Ill upload a pic of it soon!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
