Old 02-27-2011, 11:41 PM
red56turbo's Avatar
Nice 129! These 129's are nice tractors.
Josh
Diesel Cub Cadets...........
Old 03-01-2011, 09:02 AM
thetucks thetucks is offline
WEll I continued soaking the pin on the left but ir still only comes up just a hair. If I push it back down it stays down until I start the tractor. Then it moves up just a hairn not enough to get some pliers on it or anything. Can this be unscrewed and cleaned up or what? I went ahead and started it up and drove it around the yard yesterday for about 10 minutes hoping it would work it up. But it did nothing. The motor sure smokes like a freight train.
Old 03-01-2011, 03:50 PM
ihnick's Avatar
ihnick ihnick is offline
i had one that had to much gunky paint on it and it wouldnt pop up. just screw out the valve and on the bottom theres a little hole. i took a really small punch and pushed it up in the hole and just pressed with my hand and it popped up
Nick.
Old 03-01-2011, 03:52 PM
THanks ihnick... Will the left button down not let it go into reverse? Thanks
Old 03-01-2011, 11:30 PM
ok I unscrewed the left valve and got the button unstuck. Now the forward and the reverse works. It is very very quick in forward and kinda slow in reverse. is there an adjustment for this??
I then decided to take the head off this motor to check the rings. the motor smokes really bad. here is a couple pics of what I found. is there suppose to be side to side movement in the piston? I made a small video of it moving but couldnt figure out how to load it.
Old 03-01-2011, 11:31 PM
The 4th pic you can see the gap in the rings.
Old 03-02-2011, 07:31 AM
Judging by the amount of oil on top of the piston and the gap between the piston and bore, I'd say that engine is pretty worn out and is going to need a rebuild.
Old 03-02-2011, 07:39 AM
hey matt can I order the regualar rebuild kit or do I have to have it bored? thanks
Old 03-02-2011, 08:06 AM
You need to take the engine apart and measure the crank and bore per the manual to determine if you need an overbore.
Old 03-02-2011, 08:17 AM
OK thanks.
