Old 08-07-2011, 02:50 PM
dieseldan123's Avatar
Braved the 100 degree heat, and got some yard work done!
Nice pic ACecil! Looks like you and the 100 are enjoying some great seat time despite the heat!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 08-07-2011, 04:24 PM
Looks great Allen!
Old 08-07-2011, 04:53 PM
Thanks guys!
Old 08-07-2011, 05:23 PM
I've never seen someone have to sweep up so many leaves in the summer, but then again, I have mainly willows around the yard so not much to sweep up, lol. But I think Allen likes his sweeper as much as I love mine. I never knew how good they worked. Looking good Allen.
Old 08-07-2011, 06:43 PM
Thanks guys!
Bill: The sub frame looks good on the 100. I feel silly to say this, but I don't have the sub frame in the right location, on the right footrest side. Jenn and I, are having a problem getting to the bolt, so we can't get the right footrest off. We'll get it though!
DWayne: You got that right, I love the sweeper! The bad heat is making the leaves fall earlier.
Old 08-07-2011, 09:42 PM
MrsACecil's Avatar
MrsACecil MrsACecil is offline
Yes, it just don't feel right raking leaves in end of July/early August especially in this horrible heat! I'm ready for the cool weather!
Yep, Al does look good using the sweeper. It sure does save us A LOT of time raking! The Sycamore tree sure is dropping the leaves already!
Jenn
Proud owner of a Cub Cadet 2130
Proverbs 3:5&6
Old 08-07-2011, 10:28 PM
Looking good ACecil
Old 08-07-2011, 10:41 PM
Thanks Diz!
Old 08-09-2011, 12:15 PM
steveyrock's Avatar
steveyrock steveyrock is offline
Default 1250 hydro cork gasket replacement
I pulled the transaxle out of my 1250 this morning to replace the leaking cork gasket between the pump and differential houseing.I will also do a trunion weld repair at the corners of the spring plate.I orderd new springs and cups.I need to shim the linkage so I got some .010 washer shims.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 08-09-2011, 12:20 PM
Wow, that trunion has some pretty good wear in all corners, but nothing too hard to fix. Looks like you have all the bases covered.
