Old 07-30-2014, 10:02 PM
paulhentschel paulhentschel is offline
Default my 102
I picked up this cub 102 today in Michigan.I didn't actually get it but I sent my brother to pick it up.It will be coming to Alabama in the next month or so.I have another 102 to be it's stable mate!
Old 07-30-2014, 10:41 PM
Diesel Krazy's Avatar
Diesel Krazy Diesel Krazy is offline
Good find, nice 102.
Original- Wheel Weights, AG tires, Brinly Sleeve Hitch, #2 Cart
882- 50c Mower Deck
2182- 60c Mower Deck, Rear PTO, Cat 0 3-Point, Brinly 60" rear blade
Case 646 FEL
Case 446
Old 07-30-2014, 10:49 PM
Good looking 102.
Old 07-31-2014, 09:04 PM
Calvins66Cub's Avatar
Default 122 with a big load
I've got a big load to go to the dump tomorrow.
My 122 gets a little workout pulling this around.
1966__122 Cub Cadet.
Owner: Calvin, 6 yrs old
Dad: Craig
Old 07-31-2014, 10:11 PM
Looks like the 122 is up for the task.
Old 08-01-2014, 10:46 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Default and....
John, I'm enjoying my hydros. I do miss Dually at times.
We miss seeing his pix!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-01-2014, 10:50 AM
rwairforce rwairforce is offline
When you do a job such as this I'm guessing you don't have it on full throttle.
I've pulled my sweep around with my 149 using a quarter throttle or so and the battery went dead. Would this indicate my S/G need attention or the voltage regulator needs adjusting??? thanks.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-01-2014, 12:27 PM
I pretty much idle, or at the most 1/2 throttle. I have noticed too much idling causes my battery to go weak. I watched the charging with a VOM and found that about 1/4 throttle it starts to charge, so I try to run it there now more often. I would check to make sure it is charging first, and then at different RPMs. Mine does not charge at idle, but my idle is low.
Dad: Craig
Old 08-01-2014, 12:55 PM
Thanks for the info.
Randy
John Deere 140 H3
Sears: GTV16
Old 08-04-2014, 08:08 PM
mcieliesz mcieliesz is offline
Default My 1964 Cub 100
It's finally done and running
