Old 08-23-2011, 02:04 AM
CC1650Dave's Avatar
Originally Posted by jsoluna View Post
.. Really made the tractor look less cheap than it did with the sticker'd stripe and fake lights.
ha - not being familiar with that model, I remember looking at your acquisition pics and I wondered what was up with that back strip. I thought they looked like fake tail lights.
Old 08-23-2011, 10:41 AM
jsoluna's Avatar
jsoluna jsoluna is offline
Thanks guys It's great to have a place share my obsession!
Old 08-23-2011, 10:17 PM
dieseldan123's Avatar
Got some seat time at home, finally, with the newly acquired 2186. Got all the customer's lawns taken care of, and my own lawn done. It occurred to me that the temperature was changing quite a bit - and that fall was on its way for sure.
So, I loaded up the cart with several loads of firewood for the wood stove and another two loads (not pictured) of cinder blocks for a bonfire ring. The 2186 handled it all very well, the Power Tracs are an awesome tire. Daughter Fayden loves Dads new Cub too
As far as what I did FOR the Cub today...
Wired in the quick adapter for the battery tender, tightened up and greased front axle, greased front end and wheel bearings, replaced balljoints, greased both steering zerks, re-greased spindles, idler shafts, and dual pulley. Lubed up deck lift linkage and FWD/REV shaft bushings. Installed E3 plugs, fuel filter, oil filter (Kohler xtra capacity) and put some synthetic oil in the engine. Topped off trans fluid. Did this over the past week to take care of the initial services at 170 hours. Even if it didn't NEED it, I did it, just to make sure. You just never know.... Only thing left is hydro filter, which PO said was done at the 100hr service interval.
At the end of the night (a few loads were hauled after dark), I had some free time while the wife and daughter went to town. Used that time wisely. Ripped off the cheapo "Series 2000" sticker along the back fender pan and drilled holes to mount LED tail lights! No pics of the lights yet...need to run a power feed for them, then they're ready to go. Really made the tractor look less cheap than it did with the sticker'd stripe and fake lights.
Nice Cub and cant wait to see the tail lights! If your not careful she just might start claiming it as hers!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 08-23-2011, 10:39 PM
jsoluna's Avatar
Here they are! My old school phone doesn't take the best pics, but you can get the idea.
Old 08-23-2011, 11:29 PM
Tough looking cub, ya got there!
Old 08-24-2011, 05:40 AM
william1041200's Avatar
Those real lights made a huge difference!
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 08-24-2011, 05:50 AM
steveyrock's Avatar
steveyrock steveyrock is offline
Those lights look good, sets off that back end nicely. Why didn't the factory do that, lol.
122-snow blade and 42 deck, wheel weights, fluid filled tires,chains
106-42"deck
1250-44 and 50" decks
147-44"deck
2155-42"snowblower 38"deck, chains,suitcase weights
Exmark Quest-zero turn 42"deck 23hp Kawasaki engine
Old 08-24-2011, 06:43 AM
jsoluna
I agree, the lights look cool
Old 08-24-2011, 11:43 AM
jsoluna's Avatar
I agree guys, it really shoulda come like that from the factory. That glued-on stripe with fake red lights on either end really made it look chinsy. Now all I need is some sorta Cub logo in the middle of the rear fender pan.
(I was half tempted to put an IH logo back there, but that'd just be wrong, i know)
Old 08-25-2011, 08:10 AM
steveyrock's Avatar
I had very weak reverse motion on my 1250 after I did the trunion repair. The manual check valves were frozen for along time and I knew it as the buttons on top could not be moved,even after a good soaking with Kroil.I orderd a set of the automatic valves from L J Fluid Power and put them in.I test ran the tractor and realised the potential this drive unit had all along while I thought it was operating good enough or so so.The reverse is very positive and powerfull now and the forward motion speed and torque were increased dramaticaly to the point of being dangerous at full throttle with the control lever pushed up to the max. lol
This tractor could be pushed around easily when not running because of the frozen valve plungers letting fluid by pass.Just thought I would share this because for me it was money well spent to correct the situation.
106-42"deck
147-44"deck
