#3501
The 100 is an awesome tractor, Duke! Thanks for all you done, to make it a great 100! It's definitely a keeper, my friend! Might get the blade mounted this weekend.
#3502
Thanks Allen! It's going to look so sweet with the front blade on it!
#3503
I'm thinking on it I'll have to ask the guy first. I have a motor getting bored out. The 1000 is parted out but has the rearend,frame,tires,axle, and i thank the dash tower. No motor or hood and grill. What would be a good price for it?
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
#3504
Allen,
I am glad Duke hooked you up and he is truly someone to look up to.... ![]() Well I was having problems shifting the 72 the other day so I had to split it to see what was going on in there.Looked pretty good in there no rust or water,I drained out the fluid and did not see the proverbial Niagara Falls coming out the drain hole... ![]() One fork was rubbing against the other so I loosened the shifter fork bolts and tweaked them slightly.Filled it up while I have the shifter off and then worked on the clutch.They replaced the disc and the trued up the plates but the T.O. bearing was shot,and so was the teaser spring.New parts and were good to go. Picked up some N.O.S. hubcaps at an IH dealer and put them on the 72.
#3505
Very sharp 72, Lew!
#3506
Awesome 72 Lew! I love your white wheel weights! Thanks for the kind words too!
#3507
great looking 72 lew.Love the hubcaps.
Jed Proud to be a FFA member Westmoreland,TN Chapter 1978 Cub cadet 1450 IH Hubcaps 1975 1650SGT Work In Progress 1974 cub cadet 129 with sleeve hitch/spring assist 1974 108 (Mint) #510358 brinly 12 in plow,disc,8 in plow ,2 42, 2 44A ,50A DECKS #40 boxblade,can`t keep up with the rest lol ![]() ![]() ![]()
#3508
Gotta start them young!
![]() I may need to extend the hydro lever for her |
#3509
That's a great pic! You got that, right!
#3510
Great pictures, guys!
![]() Yesterday I found another yellow and white 82 series, .........An '87 1810, with about 750 hrs. Does need some work, and I haven't heard it run yet......but it does have compression. I don't have much in it...so I couldn't resist! ![]() Do have side panels, and front PTO.....just not installed.
-105___ Tiller |
