Old 10-30-2011, 06:42 PM
simpleman's Avatar
simpleman simpleman is offline
Default Moveing a little VA dirt
982 and new blade and tires
Old 10-30-2011, 06:52 PM
The tractor matches the leaves!!
Great pics.
Old 10-30-2011, 09:07 PM
LarryW's Avatar
LarryW LarryW is offline
Simpleman,
Nice tires! Looks good!
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 10-30-2011, 09:44 PM
The 982 looks great flexing its muscles!!
Old 10-30-2011, 09:51 PM
Sugarmaker's Avatar
That 982 looks sweet in the dirt!
I used the 86 to haul four loads of fire wood today while the 147R just set there and watched
Regards,
Chris
Casbohm Maple and Honey
www.mapleandhoney.com
Old 10-30-2011, 10:06 PM
cub1450's Avatar
cub1450 cub1450 is offline
Done some yard work today.
The 1042 had lesf sweeping duty and the 129 had hauling duty.
Jed
1975 1650SGT Work In Progress
1974 108 (Mint) #510358
Old 10-31-2011, 12:00 AM
Nice cubs, guys!
Old 10-31-2011, 12:06 AM
Nice cubs, guys!
Oh yeah! Lots of sweet pics and updates!
Old 10-31-2011, 03:06 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Default Gt 1554
This summer I picked up a 42” snow blower, weight tray a soft cab and some tires for my 1554. The blower mounts were modified to fit a Husqvarna and the belts were not original. After fabricating and modifying the brackets a little more it’s ready to go. The rear tires are ATV super swampers got (4) 26x12x12 w/ATV rims. The stock 16x6.50x8 fronts are to be replaced w/4.00x8 tri ribs from tucker tire w/tubes. I installed flashing LED lights for safty by the road, thry almost hit me last year. I needed to lift the rear fender assy. 3” to fit the rear tires. I put the unit into service on Sunday w/8” snow, as you see I still need to paint the Sears ss12 rims, mount and fill the ribs and install tubes, fill the rears also. I am using nontoxic RV anti-freeze it costs a little more than washer fluid but safer for my critters, both are way less corrosive than calcium chloride. I should end up with +/-80lbs rear and +/-15lbs front each, I have 100lbs ice melter in the can on the back, I also have wheel weights if needed; I would prefer not to use chains. You enjoy the pics; I get to enjoy the tractor. I’m hoping for a DV cam for Christmas, than look out Utube!!
Clay
Old 10-31-2011, 05:01 PM
Nice cub and blower!
