Old 06-18-2013, 11:09 PM
macman81's Avatar
macman81 macman81 is offline
Originally Posted by cubby102 View Post
Where there isn't hydros there can be electric actuators. I do have a parts machine to make it out of. I can even use a electricram to engauge/disengauge the deck. But I will be following this close and taking notes on what does and does not work
glad i could be your guinea pig lol.
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 06-18-2013, 11:43 PM
cubby102's Avatar
cubby102 cubby102 is offline
Lol mines still months from being started. I still have to finish the tractor first and I have to get this 129 done before I can finish mine
1872 - 60"haban 54" power angle haban blade
'63 Original - restoration project
582 -tiller
147 - leaf duty with bagger.
1811 - Ditch mower
800 - have it just cuz its a 800
Old 06-25-2013, 08:53 AM
macman81's Avatar
In order to play with my new mower when its done, my 782 needed rear hydraulic ports. I am just splitting off the spool valve with 4 tees and running it out the back with the oem hoses they used for front ports. think the hoses came off a 1811. the couplers are used off a 300 series john deere. I was able to do the whole retrofit without drilling any holes in the machine whatsoever which was nice.
will post more pics when im done with the plumbing.
John,
PROUD OWNER
Old 06-25-2013, 08:58 AM
macman81's Avatar
the hoses were dangerously close to rubbing on the hydro linkage so i bolted in a metal strip to hold them tight to the frame. there was a wiring clamp in this location i just removed it and then bolted the strip in place. holds the wiring and hoses nice and secure.
John,
PROUD OWNER
Old 06-25-2013, 10:39 AM
4 ports off a single spool valve?.... Why? .....
They look great though!!
Old 06-25-2013, 11:08 AM
Good work on the hydraulic ports! Please keep the pics coming.
Old 06-25-2013, 12:24 PM
Berwil's Avatar
Berwil Berwil is offline
Looks Great!!
Old 06-25-2013, 07:50 PM
macman81's Avatar
Actually i have a two spool valve. I know this looks crazy let me explain. The main spool is used to lift and lower the deck. The one out the rear that is tee'd in will simultaneously lift and lower the pull behind deck and the main mower deck.
The second spool can either be used in front to angle my blade, or out the rear to swing the hitch on the pull behind or run other attachments i haven't built yet.
Since i will never be using the blade and a rear attachment i figured splitting both spools will work for what i need. Hope you all can follow my logic.
Anyway, got the plumbing done now to reassemble the tractor and get on to building the hitch on the pull behind.
John,
PROUD OWNER
Old 06-25-2013, 10:14 PM
Very nice! Thanks for the pic.
That makes sense! I didn't realize you had a dual spool.... Got it now!
