#31
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
#32
Josh Diesel Cub Cadets........... |
#33
I would really like to do the CV conversion.
The pics and video are helpfull.
3 original cubs 1512 diesel Ingersoll 3012 John deere 855 |
#34
when i did mine i just cut the shaft cuz it was too short used a peice of 5/8 id dom tube had laying around to sleeve it. taco i allready made the rear one for my non splined 782 pump and as sam said i drilled and tapped it a 90 degrees fo some grub screws
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
#35
Drive shaft and belt.
Yes I noticed it when it was done. Was going over the photo's and there it was big as day. Guess I overlooked it when trying to get the shaft installed. but now it only takes four bolts and the belt can be replaced. |
#36
782D drive shaft
No did not take any photo's of the shaft before installing it. Best I could do is this one. You can see the back half and the weld. Cut a piece out of the original shaft so the two remaining pieces would equal the length I thought would work. Then the two pieces were pressed into a 2" sleeve and welded in a lath. With room for the joints to move on the splines. Allowing for the flex of the engine mounts. The 15 5/16" was the measurement between the surface of the front adapter and the surface of the rear adapter: On my 782D. Joe |
#37
Well I am going with a factory drive shaft, picking it up today. My question is, is there any reason to use pins in the drive shaft instead of bolts n nuts? IF bolts will work just as well, should I use a soft bolt or a hard bolt?
As for the steering gear, I am waitin on the upgrade, and cam follower. Most everything else is done, small coolent hoses, alt belt, stat, starter conversion, and glow plug conversion are finished.
#38
Spirol pins only or you will egg shape the holes and then you will get to replace everything all over.
#39
Thanks for the response Sam, I am having problems finding spirol pins, or even a cub # on them. Anybody have a source? Is two roll pins ( 1 inside of the other ) a bad idea also?
#40
Ace Hardware, Napa, possibly Menards, stores of that type should have what you need. And no, that's not the best idea.
-Ryan
