Old 06-28-2022, 12:30 AM
Farmall450's Avatar
Originally Posted by 1711Cub View Post
Great finds!
Thanks. This is an expensive hobby.
Carb is dialed in pretty good. Once I get the wiring sorted out it will be ready to test the haban.
Old 07-09-2022, 12:01 PM
Farmall450's Avatar
Dealer finally got my keyswitch in. Removed the previous owner's wiring nightmare back to the original harness and determined it needed a swtich. That took a bit to come in, but resolved the lingering issues after cleaning up the solenoid terminals.
Also fixed the overcharge issue
Old 07-09-2022, 09:59 PM
Farmall450's Avatar
First mow in the books. Actually mowed really nice, and the ancient CCC belts haven't disappeared yet.
Old 08-07-2022, 03:05 PM
Farmall450's Avatar
I noticed I'm losing the left cylinder at idle. Not sure why -- both compression tested the same, right at 100psi. Ordered plug wires b/c I noticed the left one can shock you through the cable.
I don't think it's the coil b/c the spark is pretty consistent on both sides when tested. They both pick right up with throttle, so I'm not sure what's going on here.
Old 08-12-2022, 05:13 PM
Farmall450's Avatar
Plug wires showed up- hopefully I can trim to length and have some success.
Old 08-13-2022, 10:02 PM
Farmall450's Avatar
The window A/C foam worked pretty good between the shroud and firewall.
Old 11-30-2022, 02:30 PM
Farmall450's Avatar
All was well after some new plug wires. I did put on the 3 point and mowed a bit more. It's ready for winter now - needs some more hard use and possible carb work/adjustments (hunts when cold) in the spring.
Old 11-30-2022, 03:54 PM
blackcloud77 blackcloud77 is offline
Throwing another option out there, just posted same in another thread. After much research, the sage advice I ended up following was just to use a regular automotive type acrylic urethane single stage paint. Will be FAR more durable than the enamels sold at hardware stores. I ended up using Wimbledon White from Summit Racing which is priced very well. Not everyone wants to spray with a gun, I get that...it's a little more involved for sure. But man it looks good. My machine is a good bit newer so I don't know if the whites have changed over the years, or if you even care...but I think these really came out great.
Paints are $30/quart...so 2 colors plus the $40 activator and you've got a whole paint job for $100.
I had some rust repair to do on mine, so I went down to bare metal and used an epoxy primer. I highly recommend this step if you're doing anything similar. $26 for a quart of primer and $22 for the catalyst, also Summit Racing brand.
Old 12-01-2022, 06:57 PM
Farmall450's Avatar
That turned out nice. I plan on spraying with a gun if I repaint this one, but Rustoleum Almond is such a nice match...I wonder if it would accept some hardener (should?).
Old 04-16-2023, 11:02 AM
Farmall450's Avatar
Got the 982/4 out this week. Greased, checked tires, and plug aerated (3 point attachment). Seemed to work pretty good. Dropped the oil in it afterwards; lots of small things to do during this rainy weather.
