#31
Just to clarify my comment in order of operation.
1. Examine the situation to find the problem. 2. If simple fix (pin, etc) make the repair and go with it (very cheapest solution) 3. If not simple you decide how you want to fix it. Option a: remove clutch replace with fix driveshaft and needed parts. Option b: remove clutch and replace it with another clutch. As I mentioned earlier I saw little difference in cold weather starting with and without the clutch. These 3 cylinder diesel start hard in cold weather (I have not upgraded the starter or glow plugs). As an FYI cub cadet sells the specific plastic fan for the disconnect clutch for $91.55. Yes just the plastic fan. I had a stick go up into the frame and take off every blade in less than 2 seconds. Since I haul all my firewood with this tractor I suspected it could happen again.
1512 with CADloader 507, CADdigger 508 and 3 pt 1711 with KT17 782 with KT17 and 3 pt 104 |
#33
Put the screen back on the bottom and sticks can't get to the fan....
