#31
I told that story to say this: Yeah, if there is a backfire, gas can (and will) ignite out the carb. Here's a secret..... STAY CALM! Crank the engine more. It sucks the fire into the engine where it's safe and puts it out. Now, if it catches something on fire outside of the carb, you might have to put it out.... but unless you are being careless, it shouldn't be that big a fire. Like I said, on the side draft carb like the K series uses, it's a little tougher to use gas. Either is a lot easier...... but seriously.... you can pull the filter off and look into that carb and see if it's fueling. Like I said earlier, if you can't figure out if an engine is missing fuel or spark, you shouldn't be working on it. Crank it. You will smell gas. Pull the plug. If it's getting wet, it's getting fuel. (Or water, whatever happens to be in the bowl of the carb). Testing spark is pretty easy too. Not hard diagnosis to make here. It's like step 1 in the diagnosis process. |
#32
LOL.. not a secret to me I have had a few of the younger techs freak out when it happens on a car or truck engine but quickly tell them to crank it.. Im glad you brought it up for people here that do not know that trick tho.. Ive see a few engines ruined by chemical fire extinguishers when all they had to do was crank the engine over.
#33
Lol. Yeah, I've seen that too. I've yelled "CRANK IT, CRANK IT, CRANK IT!!!" To the guy on the seat a few times, lol.
#34
Dealer...
Found a dealer near me... stopped by to make appt for warranty work. Did this tuesday.
They said wed/thurs pick and would call in the am to confirm pickup time. I finally called today thursday eve 4 pm. " oh um i cant find your mower". Yes I replied. You havent picked it up. Sigh........ |
#35
Terry O,100,72,102,123,104,124,105 125,129,149,1200,982 (2)2182s w/60in Habans 3225 |
