Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 04-30-2015, 07:41 PM
Roy Najecki's Avatar
Roy Najecki Roy Najecki is offline
I just checked the Small Engine Warehouse website and they have a $72 flywheel adapter for a Honda engine to IH 982 drive shaft. I wonder if that would fit a 782 drive shaft? Nine years ago they offered an 18HP Honda engine with the flywheel adapter for the IH 682/782 so they probably do have an adapter on the shelf.
Old 04-30-2015, 07:45 PM
That should work. Your probably still going to need a new drive shaft, my guess is the length will need to be changed. Wiring will be custom as will exhaust.
Old 04-30-2015, 08:19 PM
OK I just checked the SEW site and the 982 adapter won't play, BUT they do have drawings of the adapters so I can see what the Honda end looks like and I just happen to have the dimensions for the Cub end SO it should be an easy job to draw up something that will adapt a Honda to a Cub and as long as the Harbor Freight engine is in fact the same as a Honda........... well Houston we may be on our way. Gotta get out the old fashioned drafting tools and see what I can come up with.
Old 04-30-2015, 11:48 PM
Man, I was at China Freight yesterday and they had a 22HP on display. I coulda taken some pics of the flywheel for you guys. I'm not 100% sure but does the Honda take a 3 bolt adapter because IIRC that's what this had.
Old 05-01-2015, 09:33 AM
Did a little digging around on the green site, they have a few that have been re-powered with these engines. Borrowed a pic of the adapter. Looks like no big deal to make one to fit a Cub.
File Type: jpg Installing%20Drive%20Shaft%20Adapter.jpg (17.4 KB, 662 views)
Old 05-16-2015, 09:35 PM
Tunames Tunames is offline
I believe I read that these engines have a 5 amp chargeing system and won't work with an elec. PTO. Can anyone confirm this?...
Old 05-17-2015, 07:57 AM
I can't find a rating for the charging system. Guess you need to call or e-mail the tech line.
productsupport@harborfreight.com
For technical questions, please call 1-888-866-5797
You should also read the reviews, seems they have had at least one that the PTO shaft broke off doing damage to what ever it was in.
http://www.harborfreight.com/22-hp-6...epa-61614.html
Old 05-21-2015, 11:39 AM
OldSkull's Avatar
OldSkull OldSkull is offline
The question is, in what kind of machinery he was in? What can cause a crankshaft to broke at the PTO end? I know this is a $699 Chinese Honda clone but you need tremendous torque to broke a 1" shaft like that. to bad the owner didn't give all the details.
For the idle issue, why don't just throw away the crappy Chinese EPA certificate carb and fit a Honda used one you can rebuilt and adjust?
Gilles.
1963 100 (red)/in storage
Old 08-13-2015, 03:00 PM
What I was able to find is they have a 7 amp charging coil(s). Could someone add a just a stator? Or would you need to add a completely different system?
Old 10-20-2015, 07:15 AM
MWShaw's Avatar
MWShaw MWShaw is offline
Sam did you ever do anything else with this? My 782 my be a candidate for a new motor.
