Old 05-05-2011, 09:40 PM
CC1450's Avatar
CC1450 CC1450 is offline
I loosened/tightened mine with a pair of pliers rather than chewing up a socket.
-Mark
1978 1450
1976 1450
Old 05-05-2011, 10:07 PM
Wayne Wayne is offline
I wish I knew what you guys are taking out with sockets and nut drivers, cause whatever it is mine must still be in there.
Old 05-05-2011, 10:42 PM
The part that your needle with the rubber tip sits in.
Old 05-05-2011, 11:20 PM
CC1450's Avatar
That is what I was talking about sorry. I originally tried to fit a socket on it but you need a very thin walled socket and I didn't want to modify my snap on stuff. They won't replace it when it breaks that way.
-Mark
1978 1450
1976 1450
Old 05-05-2011, 11:34 PM
Oh, you mean the thingie? Mine was easy, it is slotted for a screwdriver...
I cant find any leakage from the float so I cant find a hole. I did find a spot where it looks like somebody before me may have sealed the gas inside. Hmmmm... I'll price them tomorrow and if they are free I'll get one.
Old 05-06-2011, 12:21 AM
cub108 cub108 is offline
ok,
installed the new kit. went super easy. now, my problem. installed the O ring and the float baffle then the screw for the bowl. the screw is now leaking gas. It has the new gasket washer thing on it and the screw is tight.
Is their another way to stop the screw from leaking? washer on the inside too? orange plumbers tape around the last two threads?
It just seems it's one thing after another.
Old 05-06-2011, 07:59 AM
I have had that problem for years on my 108. I just tinkered with that screw, sometimes tightening it beyond what I thought was smart, and sometimes backing it off a little. It never worked 100% for long. Its a frustrating problem. I was hoping it might stop when I replace the gasket in my kit, but maybe not...
Old 05-06-2011, 06:01 PM
I'm happy to say my 108 carb rebuild is done, and it even runs! Next time the blindfold, for sure.
Unfortunately mine leaked a bit too afterward. I think I have it stopped now after tightening up a bit, but only time will tell. Cub108, I wonder if the bottom if the bowl gets a bit bent out of shape after a while? I had that idea after installing mine, so I couldn't check it. Hope you solve your leak soon.
Old 05-06-2011, 06:08 PM
Congrats Wayne! I knew you could do it! They do sell replacement bowls. Next blind folded with the video camera recording it too!
Old 05-06-2011, 10:58 PM
Glad you got it straightened out, Wayne!
