Old 09-20-2011, 08:02 AM
Just to clarify...they should ALL be steel...the mower deck pulleys are stamped steel, and the tiller ones are billet steel.
The snowthrower must have a CI or steel pulley, because a die-cast aluminum one will explode and kill somebody.
Old 09-20-2011, 05:52 PM
LarryW's Avatar
LarryW LarryW is offline
ok, I meant I have one cast pulley on my mule drive. I also may have been confuse because I thought we were talking about the mule drives only. Not the pulleys on the gearbox, etc...
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 09-22-2011, 08:34 PM
LarryW's Avatar
Took some pictures of my updated cut off and shortened lift and what I want to do to it. I also show the adjustability of it. You can change lift travel or amount of lifting leverage. There is also a picture of a bolt I want to cut the head off and drill the a hole in the shank to work more like OEM.
I also happen to stumble on a pulley I had laying around. Might be a good mule drive pulley. Its greasable with roller bearings and heavy cast. Grease zerk in bolt shank but missing.
ok I give up, every dang time I get a few different pictures uploaded I get the error 500 and have to start over. I will try later
Cub Cadet 1811
Old 09-22-2011, 09:46 PM
LarryW's Avatar
ok I will try it again. Looks like I didnt loose the pictures. Here is the pulley I found.
Cub Cadet 1811
