Old 12-02-2011, 11:45 PM
Originally Posted by old piddler View Post
You guys were right from the beginning, I fretted over a couple switches that ment nothing as far as starting. I left the seat switch unhooked, found out the one hanging below the ignition switch is the reverse indicator, I cleaned up the battery terminals and cables, made sure everything was tight on starter and now it starts like a new one. I even got the deck off and cleaned a ton of compost out of that, finding out the blades are as good as new without even a nick. I will get all that cleaned and painted soon. Fellows I was the nut between the steering wheel and the seat but it was a productive day.You were right about that switch Dave, thats ecactly what it was.
I edited your post. Please do not post how you bypass safety switches.
I am glad that you got it fixed.
Old 12-02-2011, 11:54 PM
Glad to see, you got your cub going.
Old 12-03-2011, 04:40 PM
old piddler old piddler is offline
Default Don't Bragg to Soon
Tried to start the 1864 this morning and just got a click from the selonoid, after a few tries it starts. How should I decide if I need a new one or just the relay I see you posting about?
Old 12-03-2011, 05:38 PM
Dave01's Avatar
Dave01 Dave01 is offline
Aha, now you have exactly the same problem I have on the 2084!
Well, I've lived with the problem for 2 years now. I can't say it particularly bothers me, but I should fix it. From what I've read here I would expect that a relay would solve the problem. It's a cheap and easy fix so I'd suggest you give it a try.
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 12-03-2011, 10:48 PM
Thumbs up The Relay
Dave it just bugs me so much I have to try the relay, I will always wounder when the time may come when it wont start and where I might be when that happens. I read that you shouldn't push the tractor very far if the motor isn't running. How far is to far do you think?. I will do some reading on the relay and give it a try, let you know what happens.
Old 01-10-2012, 08:50 PM
Default Gave a Battery a try first
Dave, I put another battery in (not a new one) and it'sbeen starting ever since but to be on the safe side I have a relay on the shelf.
Old 01-10-2012, 10:41 PM
Dave01's Avatar
Great news! The simplest fixes are the best ones for sure.
Old 01-10-2012, 11:33 PM
Well said!
Old 04-04-2012, 11:06 AM
Cool 1864 Cub Cadet
Since I bought the tractor used, I want to change all fluids, I can only find a synthetic Cub oil is it ok to use regular Hy-Tran oil?
Old 04-04-2012, 12:30 PM
Sam Mac Sam Mac is online now
HY-Tran for the hydro.
