Old 02-15-2012, 07:13 PM
$$$$$$ anytime.
Old 02-15-2012, 10:01 PM
EricR's Avatar
EricR EricR is offline
Trailer looks great Dwayne, question, how long and wide is the Cub hauler?
Reason I ask is I have a snowmobile trailer (worthington 102inch wide X10 foot) and yours doesn't look much longer than mine? Yes mine tilts and won't stay up either so I have been throwing around the idea of getting a longer hauler just to haul more than 2 Cubs at a time!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 02-15-2012, 10:08 PM
It's 93" wide x 144" long. This was a snowmobile trailer at one time. I really like the size of it. I could see hauling maybe up to 4 cubs at a time. 3 easily.
Old 02-15-2012, 10:21 PM
Merk Merk is offline
I wouldn't be worried about the length and weight. I would how much weight it can haul. There should be a tag on the trailer somewhere.
Old 02-15-2012, 10:30 PM
EricR's Avatar
Merk my trailer I think is road worthy for 1 ton!
And thanks for the measurements Dwayne, got me thinking more.
Your trailer is looking great, DWayne!
Old 02-15-2012, 10:36 PM
Thanks Allen, it was nice to be able to get out and use it some today. We actually had some short sleeve weather for most of the day.
Old 02-15-2012, 10:46 PM
by EricR
Best to know what your trailer can handle and not think.
A things to consider....
Total weight includes the weight of the trailer.
Any trailer in the state of Ohio with a 2000 pound weight limit requires brakes on the trailer. A Cub Cadet 71 weighs 550 pounds with no weight or attachments. Most of the trailers posted in this topic are lucky to handle 2 Cubs.
Each tractor should have 4 seperate tie downs. Wraping a strap around the dash tower is poor set up.
Connecting a strap to a 3 point hitch is a poor set up too.
Old 02-15-2012, 11:01 PM
I thought about the 3 point strap issue when I got back home this afternoon and agree.
Old 02-15-2012, 11:18 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
to add to the ohio law. you must use 4 rigging points and each strap must be able to hold the weight load. also DOT can pull you over now and check your load and scale you if they want.
your bumper pull hitch on the van is how much? 500 lbs? you dont want to be axel heavy (thats a fine) you may not be over weight but you can be axel heavy.
looks like you have 2 1000 lb axels , check the load of the tiers ( DOT will )
so you can haul 2000 lbs that includes the weight of the trailer. so if the trailer is 500 lbs , you can haul 1500 lbs. and still need to find the sweet spot on the trailer so your not axel heavy.
Doug
Original , 100 , 125 , 582
