Old 09-20-2009, 09:13 PM
clint clint is offline
Same exact problem my 1450 had with the worn side of piston, is the Kohler weak spot. I think it's the way it pushes the piston up, or maybe the off balance, whatever it is it's the wear point on Kohler K series or the 14 HP anyway. I bet you get lucky, and the bore is perfect, only the aluminum piston being wore.
check rubber flex disk on the drive shaft, also if it's bad rusty, or you just want to do a nice upgrade that you will no longer have to worry with the drive shaft get some Stainless round or 4140 round stock 5/8" diameter, and you can build a nice drive shaft that will last forever. When the motor mounts go it puts undue stress on the rubber flex disk, my rubber flex disk (rag joints) were shot and my ISO mounts were in good shape
Old 09-26-2009, 12:34 PM
metalrain metalrain is offline
Gentlemen:
Waiting on engine parts, weather turning colder tomorrow,
decided to do a quick frame paint on the 1450 while i can still do it outside....cleaned and degreased the frame, sanded a few areas, used a rust converter, and taped a few things off.....
Two coats of mp170 epoxy...
cool thing about epoxy...its a wet on wet application...
let it flash, then two coats of white basecoat (cool vanilla, chrysler newer 300's off white....sorry...not a purist...
I'm giving the white base 30 minutes dry time...i'll tape it off, then spray the yellow....(dodge viper yellow...sorry again...just ain't a purist)....
Metalrain
Old 09-26-2009, 01:06 PM
I'd clean off that hydraulic cylinder rod before you use it again, or the paint will tear up the (non-replaceable) seal in the cylinder.
Old 09-26-2009, 02:28 PM
Nice job, Metalrain! Thanks for the update.
Old 09-26-2009, 05:09 PM
Basecoat is on....just waiting to clear
Clearcoat sprayed.....
engine bay cleaned up....
I'll paint the bigger stuff next weekend, fenders/hood etc...etc...waiting on an overhaul kit so i can put the engine back together.
I did order the solid iso mounts...thought i'd try them and see what happens.
i'll let you know...
Metalrain
