Old 03-06-2012, 09:03 PM
Awesome news Rudy! I figured you was going to learn a ton on his project!
Old 03-06-2012, 10:35 PM
I totally agree!
Old 03-07-2012, 01:22 AM
inspectorudy's Avatar
Default One last question
After getting everything back together and taking it for a "High Speed" spin I noticed that it was a little darty. Does anyone know what the toe in should be? Right now I have it set to both wheels straight ahead and it isn't an issue when in the grass but it should track better on the road. Thanks
1811 Hydro
Old 03-07-2012, 05:48 AM
yesmar74's Avatar
yesmar74 yesmar74 is offline
I always use 1/8" closer in the front than the rear,works for me.
1973 149 with 44" Deck, 782 with Simms cab, 1966 102 with 38" deck, 50" deck, 5 42" Blade, Brinly 8" 3- point Plow, Brinly 10' Sleeve hitch Plow, Brinly 12' 3-point Plow, 782 Pile, 2-38' Decks, QA-42A,1650 Roller, QA42 Thrower, Kubota BX 2360, 1970 IH one ton 4x4, one 1959 farmall cub restored, two 1949 farmall cub projects, cub grader blade, 5 sickle bar mowers , 1 set cutivators , 1 fast hitch plow, 1. 1950s IH hay rake
Old 03-07-2012, 06:44 PM
cub149's Avatar
cub149 cub149 is offline
Glad you got it going Rudy! I knew you would get it all figured out.
Chip T.
Drexel NC
Old 03-07-2012, 06:47 PM
Default Final pictures of the conversion
Here are a couple of pics from the final reassembly. Not too much to see but the ram. As you can see from the PS valve the lines have to be put on in an order so that you can get to the last nut without interference.
1811 Hydro
Old 03-07-2012, 07:02 PM
NICE WORK!
Old 03-07-2012, 10:24 PM
NICE WORK!
I agree! Thank for the pics.
Old 03-10-2012, 12:04 AM
Default Parts question
Now that the heavy work is done I need to replace the two ball joints on the PS ram. Does anyone know the size rather than the part number? I looked them up on the CC parts site but they just give the number and not the size and thread count. Thanks
1811 Hydro
Old 03-10-2012, 08:13 AM
You could take one off and compare it to a bolt.
Most times heim joints are a fine thread, but not always.
A quick visual comparison would tell you if it is a fine thread.
I'm not familar with your Cyl. and some are L.handed, again a visual would tell that.
