Old 04-23-2012, 12:10 PM
Originally Posted by j.m.jackson View Post
Sam Mac,
I wonder if this shaft I have is from a later model something after MTD cheapened it up...
I don't think so, the later so called Cubs have a plastic barrel system for the joints. My guess is the supplier to Cub got behind on production and didn't drill them for the grease fittings or cut the snap-ring groove, but that's just a guess.
Old 04-25-2012, 08:48 AM
j.m.jackson j.m.jackson is offline
Sam Mac,
I pulled a measurement on the shaft, looks like 24 is about right.
--Mike J.
Taylors, SC
1872 - running and mowing!
1882 - in progress
1772 - in pieces, Farmall 200 with a fasthitch 2 point sickle mower, Farmall Super A with cultivators, hillers, middle buster
JD 330 w/3 point, Scag SR-18B on mowing duty
Old 04-25-2012, 08:49 AM
Here's the first pressure washing results (until the pump blew a fitting, more fun)
Any ideas on the power steering input bearing?
--Mike J.
Taylors, SC
1882 - in progress
Old 04-25-2012, 09:07 AM
Mike the plastic bushing at the top of the steering control valve should be no big deal. I think you can get it from Cub. Looks like the same one that goes in the regular steering column but I have not measured one so I can't say for sure. Your doing pretty much the same things I had to do to my Supers.
Old 04-25-2012, 09:36 AM
Sam Mac,
My steering valve looks like it already has a bearing or bushing in there.
From cubcadet.com, it's RG-061016x1 (Bearing, Column), $29, and it's sloppy around the shaft but seems to be tight in the tube. Any ideas how to get it out to replace it without tearing down the whole valve?
--Mike J.
Taylors, SC
1882 - in progress
Old 04-25-2012, 10:06 AM
I think it's plastic, I thought it had a lip on top that maybe you could get bearing puller on or maybe you could drill a couple holes in it and screw in a dent puller and pop it out.
Old 04-25-2012, 11:57 PM
I got the bushing out, I had to use some metal roofing screws and properly applied force, but it'll be much tighter when a good bushing goes back in. Now it's time to collect some parts and put it back together after a little more degreasing, 'adjustment' with a heavy hammer, and paint. Not a restoration, just putting it back in proper cub working clothes, and addressing issues. =)
I agree with the others, tho, paint quality from this era machine is, well, lacking.
--Mike J.
Taylors, SC
1882 - in progress
Old 04-26-2012, 07:03 AM
The paint isn't lacking, it's a total joke but we can blame EPA for that and the Green guys have the same problem. Nice work.
Old 05-08-2012, 04:33 PM
Wow, that paint is absolutely aweful. I hit it with a 120 grit flap disk on the grinder, and it liquified and flowed, but never came off. So back to the 150grit by hand to get the flaked and popped areas, then 400 to knock it down, then primer, sand, primer, and sand.
--Mike J.
Taylors, SC
1882 - in progress
Old 05-08-2012, 04:34 PM
Getting closer....
--Mike J.
Taylors, SC
1882 - in progress
