Old 09-28-2012, 08:48 PM
jdroison jdroison is offline
Lightbulb
i'm not sure but does the 149 have any safety switches that kill the engine, like a seat sw or such. those can get bad and open intermittently on rough ground. otherwise a wire grounding out in a wire clip could be it. most likely the one from coil to points. also i have seen wire corrode and break inside the insulation and do this.
Old 09-29-2012, 03:15 PM
johncub7172's Avatar
Cant get cold enuff here in ne. Ohio to stop a gas motor. I have seen a few trucks and tractors diesal that would not run, but the gas motor never will let you down.
Hope you get the problem solved.
