#31
Glad your making some good progress!
#32
Thanks for the pics! Please keep the pics and updates coming.
#33
You don't really need that baffle in front of the battery...in my experience that just makes the tractor run hotter.
#34
The progress is coming alot great. Keep the pics coming! I'm kinda curious on the rear end repair. My 782D I'm working on has the same repair (longer bolts with nuts). Will this hold up without problems with locktite and some sealer on the threads?
The mystery piece of sheet metal kinda looks like the heat shield for a 782 and the like.
Josh Diesel Cub Cadets........... |
#35
Red contact Rich Patton via the banner at the top of the page he should be able to hook you up with your parts list.
#36
Looking good, On the wiring at the rear end, Dont forget u have a seat safty switch and may b a pto option wire. As 4 the mystery sheet metal, the only thing on those tractors that even looks close would b around the fuel tank as a fender support. Maybe an air duct under by the engine insted of a screen. I have nothing on my 1572 that looks like that. Dave
#37
Thanks for the update and looking forward to your pics.
#38
![]() Quote:
#39
![]() Quote:
http://www.onlycubcadets.net/forum/s...ead.php?t=1308 |
#40
Nice progress on the 1772.
On my 782D, there were also two bolts coming from under the frame screwing into the radiator. PITA to get out due to rust, ![]() Sounds like you also need to adjust your hydro linkages as well. The clutch pedal is hooked up to the hydro linkages and may be tugging it slightly into reverse when depressed.
