Old 11-23-2012, 10:45 PM
inspectorudy's Avatar
Default 1811 sloppy steering
I have an 1811 that had sloppy steering and went through all of the hoops before I realized that I needed a new steering box. I bought all new ball joints for the steering and then bought a re-build kit for the steering box all to no avail. We have the three turn steering box and although that is the easiest one to turn it is also one of the most expensive to replace. I found a rebuilt one for $275 on ebay and decided to go with power steering instead. It was about double the re-built box and a lengthy job but worth every minute and penny! The problem is the steering shaft worm gear drive. When it gets worn there is no short cut to fix it. It has to be replaced. If you turn the cam follower on the left side of the box into the box until it tightens the steering then back it out just a hair and lock the nut. If that doesn't cure the sloppy steering then you may have a worn worm gear. If the tractor has had as little maintenance as you describe then it probably has no grease in the box at all which means that there probably been a lot of wear on the gear. Don't give up. Once you get this thing sorted you will be happy with it.
1811 Hydro
Old 12-02-2012, 09:43 PM
Pucknut Pucknut is offline
Next issue, as I have already resigned myself to pulling the motor and playing with the rings and valves come spring between the snow to mow seasons.
I have noticed a buzzing sound coming from under the seat, think that it's too loud to be a normal sound, and reading about the hydro reliefs...
Well I pulled the center cover and then monkey wrenched the fender cover off (thanks to whoever recommended PB Blaster, those footrest nuts were a PITA!) to see the hydro unit covered in about an inch of greasy, grimy, dirty, you know what all over it. After a minor cleanup (going to take some degreaser and hose to it tomorrow when I can see) I start it up and sure enough it's buzzing from the unit. Taking a screwdriver and ear method ensuring I was far enough from that hydro cooling fan blades (one is chipped 1x1 inch, the rest look good) that bit me once before. I isolated the buzz to the reliefs themselves. Now my unit has a pinhole on top of the valves, and both seem to be weeping fluid (would have never noticed it if I never cleaned the grime off of it) not much, but I wouldn't expect any at all.
My question is, what am I looking at now?
