Old 02-10-2013, 08:44 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
I agree with the guys here. measure up the crank and bore. check for out of round and taper. most mechanics usually will tell you once you remove a piston from a bore you have to at least put new rings on and hone the bore. reason, you probably have a slightly egg shapped bore that the rings are "fit " to from years of wear. you will never get them back in the same way. so they have to wear in again to fit and you'll probably have oil burning problems.
Tags
124, engine wont start, kohler
