Old 02-12-2014, 04:39 PM
782CC 782CC is offline
I don't know about the correct yellow, But I have to put in a mention for Van Sickle paint I found at Orschlen's. What I really like is how smooth the surface of the paint is. Especially for snow. So far wearing well. I like it much better than Rustoleum or Valspar.
Old 02-12-2014, 09:28 PM
kostendorf's Avatar
I agree, I painted this cart with Van Sickle paint and it absolutely shines and reflects in the sun. Some before and after pics. I've used IH white, red, and yellow. They all match pretty good as far as I'm concerned.
Old 02-13-2014, 12:01 AM
gsomersjr's Avatar
gsomersjr gsomersjr is offline
Your cart turned out great!
Current: 102 122 SZ60
Past: Original 71 72 73 86 100 102 122 123 124 125 127 129 147 149 169 383 582 682 782 782D 784 982 1000 1050 1100 1200 1204 1210 1250 1282 1415 1420 1440 1450 1535 1541 1641 1650 1710 1711 1730 1806 1810 1811 1860 1861 1862 1863 1864 1882 3185 3200 3205 7265
Old 02-13-2014, 05:56 AM
The #2 turned out nice!
Old 02-13-2014, 05:59 PM
That is a nice cart, and tractors!! when i was at the local farmers implement the other day (case IH) dealer, i asked them which is "better" paint; the cub cadet, or the case ih, of course they all said the case ih...well, i shot my tunnel cover with it after welding the manual valve hole closed, 2k primer, and blocked her out (had to get two new autos) and i was actually shocked at how good it sprayed and laid, hardly any peel... 8-9 bucks a can though, but didnt even use close to half a can, and has at least 4 nice coats on it, not that it needed it for coverage..it has been plowed with maybe 15 times since, boots, even kids standing and riding on it and not a single mark, very hard finish...i have been squirting for along time and would rather use my guns, but being without my good compressor (old man is trying to steal it i think!) I have been just shooting little parts with cans and i have to say that was by far the BEST...i have experimented with valspar (not too bad, prone to fading, takes forever to FULLY cure), majik (TOTAL GARBAGE) van sickle (ok, but has to be shot via hvlp with right mix and pressure for prof quality), rustoleum (good for touchup, will shear if sags or runs, all around not a bad paint) my favorite is ppg, however have not tried it for cubby parts, and i have not tried the case ih version of cub yellow either so i cannot attest to that...of course just my opinions is all...i also shot the underside with auto undercoating..so far so good...wonder if i should do the inside of the side sheilds with it??
Old 02-13-2014, 07:48 PM
Attachment 47177
Attachment 47178
Attachment 47179
Attachment 47180
Attachment 47181
Attachment 47182
Attachment 47183
Your #2 cart looks great!
Old 02-13-2014, 07:58 PM
kostendorf's Avatar
I used so much paint because I shot it out in the driveway with a slight breeze for two days, but here in Missouri you got to do it with the weather changing every day. Think I lost most of the paint in the wind, but at least the wind kept the bugs away. I used truck bed liner paint on the floor. That's a good Idea to use it on the sides too. I don't think undercoating would work because it gets hard after a while and will peel off with hard use like filling with gravel. The liner stuff is thicker and rubberized and comes in different colors like white and is made for abusive use.
Old 02-15-2014, 03:48 PM
gsomersjr's Avatar
Originally Posted by TheSaturnV View Post
With my Suburban and 147 restorations, my system HAD been to match auto paint to a selected rattle can color. In the case of the 147, I initially picked Valspar CC yellow and matched the auto color to that. I often paint small batches of things like control levers/rods, etc., and don't want to break out the HVLP and deal with the resulting cleanup and breakage/waste of the hardener which has to be used quickly once opened.
I actually called Majic this morning to let them know their TSC offerings weren't cutting the mustard. The guy sounded sympathetic enough, and his response included "government" and "lower VOCs."
There ya go.
It is true that new laws are changing VOC content among other things but they are all playing by the same rules. Some paint manufacturers are just doing a better job adapting to the new laws. On my way now to TSC to return Majic and then to Home Depot to purchase Rustoleum. Maybe one of these days I'll find the courage to use a spray gun.
Old 02-15-2014, 04:28 PM
That's a nice #2 cart. Time for yours to be done Allen.
Old 02-15-2014, 09:52 PM
It'll get done eventually, Nick.
