Old 08-11-2013, 08:45 AM
johncub7172's Avatar
Very nice job. All that work should ensure that it doesn't snow this winter! :-)
That would be just fine with me! I'm glad the repairs were this easy to preform. I know and have seen other times where the repair man was not as fortunate.
Old 08-11-2013, 09:16 AM
Nice work John!
jbrewer's Avatar
jbrewer jbrewer is offline
Nice job! I'd be a bit concerned about wearing out the C channel given the tension on the joint. A stud and 2 nuts in there carefully backed out (to expand the "C" might have allowed you to sneak up on it some.
OTOH with .030 play I'd probably have never picked up a wrench. My poor O is probably more like .3"
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-11-2013, 11:41 AM
Thumbs up
John
I never realized how much .034" of play the front axel had until I disassembled the steering components and measured. Imagine .034 thousandths of play a piston would have inside a cylinder. There was a definite audible sound "knock-knock" when turning left or right. It was like having a squeekie wheel, lol!
Mike, Thanks! Got a test run this morning, all I can say is wow! Was a fun project and wright up for me too!
Old 08-11-2013, 05:54 PM
I like this thread. It makes me want to get out and tear into my 147. You documented it well and the photos helped. I'll be checking into this thread when I go to work on mine, whenever that is. I would have never thought about measuring the gap/appropriate thickness on the axle.
Old 09-01-2020, 12:00 PM
MBY852's Avatar
MBY852 MBY852 is offline
Hey there! I was looking for a thread on front axel removal on my 127. It looked like johncub7172 did a nice job on documenting everything but no pic's to view.I am slowly removing parts here and there and sandblasting them and putting them back on. So I was wondering if removing it was worth the effort. Unfortunately all the pics were deleted on this thread and couldn't find anything on youtube either. As far as I can tell you have to remove the roll pins on both sides and knock out the axel pin, is that correct? I have that vertigo bs going on right now and laying down and looking up is not pleasant.
Thanks for any help on this. Maybe be just better to do it on the tractor than removing it?
CC Model: 127 w/42" deck
CC/MTD Model: 2155 w/42" deck
.....DAD bought em new.....
Old 09-05-2020, 10:30 AM
Should be only one spirol pin on the front.
You will have to either shim the "c" channel in place or remove the axle and squeeze with a large bolt, washers and a nut.
Either way the axle pin will have to be removed and possibly replaced if excessive wear is noted.
Good time to ad a grease fitting to the axle if one is not installed.
The 70 I have been working on did not have one so I installed one.
Good Luck!
