#31
just curious, what is so special about a 126? or is it just the creeper setup, and hydraulic stuff on it? I know where one is local for sale, but doesn't have the extras.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
#32
When I had it for a drive low works as it should. In 1:1, will work if you hold in and not too much load otherwise it pops out. So hopefully it the shifter fingers and not the gear and slide for 1:1
or the slide got put in backwards ![]() Found the headlight switch and lights that are there work. No tail lights any replacements out there ![]() Thanks for all the great comments ![]() Reread sum of my post myself A little punchy after the long day.
Doug 126 Creeper,H lift,Deck, Sleeve hitch, B Plow, Weights 129 Deck, Blade, Weights 1200 Creeper Deck: 1250 B Tiller odd deck 782R with power steering ![]() ![]() ![]() ![]() ![]() JD 110H:JD 112H |
#33
A resto is in order but it will go down the list
782 PS upgrade I have most of the parts, just need the valve support bracket. (Extreme cub parts looks like the only source) 1200 to get back together. waiting on parts
#34
Third rarest production cub made and options make it even better.
#35
Glad you got the 126! |
#36
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#37
I'd make the drive!
#38
on the creeper drive repair the shift fork for the creeper and the handle prolly are both worn so it has some play in both had a few like that here
#39
pulled the bastard hich and replace with the correct one. found a couple longer tethered bolts and walo. Next to put on the resto list.
#40
It looks good with all the options but the custom paint job is funky.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
