Old 11-01-2013, 06:06 PM
here it is assembled so far so good
Old 11-01-2013, 07:15 PM
reassembled the axel tubes/ axel carrier with sealant and the axels with new axel seals
Old 11-01-2013, 10:12 PM
Good job, Nick!
Old 11-02-2013, 12:18 PM
Good job, Nick!
X2!
Old 11-02-2013, 04:15 PM
thanks, but i am trying to install the rear end with tires on, how do you line the bolt holes up?
Old 11-02-2013, 06:32 PM
austin8214's Avatar
Use studs.
Old 11-02-2013, 06:43 PM
what do you mean use studs
Old 11-03-2013, 08:48 AM
austin8214's Avatar
Take some 7/16 20 bolts and run them in from the back side of the flange.
Old 11-03-2013, 11:43 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
when you put bluing on the ring gear and spun it around what kind of wear pattern did you have? also how much backlash did you set up the ring gear to? and how much preload on the carrier?
Old 11-04-2013, 07:20 AM
alright guys, got the rear end in and filled it with new oil, it drives great and no noises,
