Old 11-30-2013, 07:57 PM
SS5150's Avatar
SS5150 SS5150 is offline
Well, after a couple days away, I reinstalled the front cover and flushed the engine out as mentioned earlier in the thread....going to refill it and try running it again tonight or tomorrow.
Anyway, I came up with I think a 1710 (or a newer 682) with a decent running series II KT17 for a little over $100 today so I have a backup engine just in case. Hopefully I don't need it.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 11-30-2013, 08:15 PM
Did you check to see if the hoses are backwards?
Old 11-30-2013, 09:34 PM
Darrell Darrell is offline
On the Magnums I have , there is A and B marked on both adaptors that the hoses screw into.
A to A , B to B
Old 11-30-2013, 11:03 PM
SS5150's Avatar
You get the Gold Star sir, you called it. Put it back together, flushed it out, flipped the hoses, restarted it, got up to 40psi after a few seconds. Let it run for about 10 minutes, gave it a little throttle, ran good, sounded ok. One of the hard remote lines cracked on me so I shut it down and dumped the oil out again and changed the filter. Still a lot of dirt coming out, but at least its running.
Thanks for everyones help!
RUN IN THE RED
1872 project
Old 11-30-2013, 11:11 PM
Glad you got your 782 running!
Old 11-30-2013, 11:35 PM
Glad you got it going!
Kudo's to Sam! I really didn't think of that one! Chalk it up in the memory banks, for future reference!
