Old 02-10-2014, 06:42 PM
jeffmayes jeffmayes is offline
Default Broken mounts on my 1440
Par for course, an MTD that falls apart!
Here are some pics of the damage and what caused it. Notice there are missing bolts from the right side, a broken bolt on the right as well as a missing bolt, and just my luck, the right side housing was cracked! I have a good source here in Illinois in Montrose, who has lots of tractors; infact he calls it the cub boneyard!
I actually traded two snow blades for one complete setup. Almost complete, just missing the raise and lowering rod. No problem to make one of those! Basically, less than a hundred dollars and the problem should be corrected, never to return (I hope)
Old 02-10-2014, 11:07 PM
That is the setup I was using. I believe it is a part of my problem.
Old 02-10-2014, 11:17 PM
Originally Posted by Mcamp View Post
Some pics. of the mount parts.I can't get to the only complete one it's under a couple feet of snow. most of these blades i've seen were on old narrow frame tractors.Maybe because of hard to find mounts?The extension on the tube under the tractor allowed for use on several applications
I traded two snow blade setups. one was like the one you have pictured here, and the second was the correct front end parts, but was modified to fit another unknown type of tractor. The one I got has everything except the push pull rod, which I can easily fabricate!
Old 02-10-2014, 11:46 PM
Thumbs up
Someone mentioned a bracket setup by Extreme. I am interested in using this setup and would like more info. Pictures would be good!
I have now got to the problem that caused the broken brackets; two missing bolts, one sheared bolt , and loose hardware. I am replacing both axle tubes, and both trany mounts. I also have to replace the trany cooling fan. I have just over $120 in order to get it back into new condition. Both the axle tubes had stress cracks inside, and needed to be replaced. The driveline couplers are in good shape, so I dont need to spend that extra money. I actually found a shop that had the gaskets for the rear end inspection plate and the axle tube gaskets on hand, and for less than $30. Pretty happy about all that! Not happy about having to go through all this right now!!
Thanks everyone for the insight! You were very helpful.
Old 02-10-2014, 11:48 PM
Jeff
You may have to remove the rear hitch plate to get a good look at the top of the axel tubes. Not a big deal only 4 bolts. 9/16" wrench and you are all set.
Do you have the correct paint number for the 1440? Yours looks really close to being the color I am looking for?
Old 02-11-2014, 06:01 AM
cengleman cengleman is offline
Jeff, I have a similar problem with my axle carriers on my 2072. Just waiting for the weather to warm up to tackle it. The guys here provided me with some great info.
http://www.onlycubcadets.net/forum/s...ad.php?t=28813
SamMac's case brace thread:
http://www.onlycubcadets.net/forum/s...ad.php?t=24353
xtrememotorworks brace:
http://www.xtrememotorworks.com/Part...rts%20List.htm
Good Luck!
Old 02-11-2014, 06:59 AM
Jeff
I sent you a PM, give me a call. I have a couple tips for you on how to fix this up.
Old 02-14-2014, 06:11 PM
Talking
Jeff
Good news! I got the brackets for the tranny today, along with the fan for the tranny cooling! Now all I need is the brackets from Xtreme Autoworks. It is intransit via UPS, but I don't know how long that will take to get here. They didn't supply a UPS tracking #. As soon as I get that, we will gitter back together and running again!! Thabks for all the help guys!
Old 02-14-2014, 06:29 PM
Jeff
Holler if I can help.
Mac
Old 02-15-2014, 08:21 AM
Good to hear!
Tags
broken, mount, transmission
