Old 03-30-2014, 04:04 PM
Plowboy1086's Avatar
Plowboy1086 Plowboy1086 is offline
AND....you want to use the 582 wiring harness to start this K-241 with a "push to start" switch instead of the Ignition Switch..??
Looking for just a custom one that I can just wire up the k241 for it to run with the charging system. With a push button start
Bi-Polar Plowboy Plowboy X Press
Old 03-30-2014, 09:07 PM
Sounds like something you need to work out on your own.
Old 03-30-2014, 09:27 PM
I figured I'd have too
Old 03-31-2014, 01:35 PM
Made my drop spindles. Have to post some pics later
Old 03-31-2014, 03:10 PM
Looking forward to them!
Old 03-31-2014, 10:13 PM
Installed. I like the looks of it!
Old 03-31-2014, 11:12 PM
Looks great!
Old 04-02-2014, 12:08 AM
Future plans. Wheelie bars, 13tooth pinion gear, 122 trans, axles and a carrier out of a 1440. Finish up my weight brackets. Then to get my hands on a motor
Old 04-14-2014, 03:57 PM
Ok guys. Who all here has built a stock altered motor? Im running the eastren garden tractor pulling rules. I hae a 37.5 cubic inch limit. What parts do i need to look for?
Old 04-14-2014, 06:55 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
steel or forged crank, heavy rod, piston, stainless valves , wide base lifters and cam max 330 lift? the good SA motors aftermarket block and a billet head. or you could give
Todd Vorhees a call or emai. He's one of the better SA engine builders out there
toddvorhees@aol.com
NQS legal 16hp Stock Altered Motor ,aftermarket block,all good internal parts very strong running motor ,ready to run $3200 for more details call 740-279-5427 thanks
they aren't cheap
