Old 02-16-2014, 06:16 PM
jimbob200521's Avatar
Originally Posted by austin8214 View Post
I gap all my Kohler plugs at .035 I prefer running a Autolite 216 as well. They are a bit hotter than what is recommend and seem to smooth things out.
I don't really have a problem with Autolite plugs, but I prefer Champion. As for gap, depending on where you look, I've found different gaps. Kohlers site (for a K321) says .30, while others say there Cub manual says .25, and like R Bedell has said in a different post, .35. I just installed a new Champion plug in my 129 with a K321 and gaped it at .25.
-Ryan
Old 04-06-2014, 08:55 AM
Steve W Steve W is offline
I'm curious if you pulled the head on your tractor and found anything with the intake valve as I am having a similar issue with my 124. I have gas puff out the carb when it's turning over.
Last summer, my 124 would only start if full choked and full throttle for 10-30 seconds of cranking (I'd slowly adjust choke down to 1/4 during that time, and then it would start). As of right now, I have adjusted and checked all the things mentioned in posts I could find about this issue EXCEPT taking the head off and looking at the intake valve. I will note that the new plug is dry when I take it out after trying to start but I have installed a new line, changed fuel in tank, cleaned carb. I don't get why there wouldn't be any fuel on the plug. I have sprayed starter fluid in the hole, installed plug and nothing happens.
I have a FEL and wasn't able to move any snow this winter
