Old 03-20-2014, 08:27 PM
Looking good Jeff!
Old 03-20-2014, 11:15 PM
Looking good Jeff!
X2!
Old 03-21-2014, 06:51 AM
That looks great. Jeff are you going to weld a plate on the end with a nut in it? I was thinking to shorten it and do that so you could either use the lew slide hammer on it or if someone doesn't have a slide hammer they can thread a tapered end bolt in it like what's on a puller to push against the crank and if the pressure doesn't make it pop off a couple wacks on the bolt should make them go too. Just a thought.
Old 03-21-2014, 07:18 AM
Looks good Jeff.
Old 03-21-2014, 09:51 AM
Looks good Jeff.
Looking forward to you next project.
I got another for you....
Old 03-21-2014, 07:34 PM
It's going to get a 5/16" x 1" bar welded to the open end that's drilled 3/8-16 for a bolt to push against the crank.
Looks good Jeff.
I lucked out on the material for this, it's the same material I use for Kawasaki 2 stroke street bike expansion chamber manifolds
Keep 'em coming
Old 03-22-2014, 12:31 AM
Looks good Jeff.
Your not the only one........
Old 03-23-2014, 06:55 PM
How's this Lew?
Old 03-23-2014, 07:16 PM
Looks like another "parts from Jeff in PA".
Old 03-23-2014, 07:26 PM
Not until it gets the "Lew seal of approval"
Make sure it works as well as we think it should
