Old 05-01-2014, 06:46 AM
Originally Posted by OffTime View Post
Hello Sam. From reading your posts, I know that you are a busy man. Just wanted a little update on the mule drive pulleys if you know any more. Thanks for helping.
I have not gotten any firm commitments so I have not done any more on this. I'll need to order at least 6 so if I get commitments for the 6 I'll proceed. Only thing I did was to decide that if I make them I'm going to use a 6203 bearing because you can pick them up at TSC along with the 5/8" X 3/8" shoulder bushings.
Old 05-01-2014, 08:23 AM
OffTime's Avatar
OffTime OffTime is offline
I will see what I can do. I may end up purchasing more pulleys than I first wanted to buy. I certainly want two. I'm not sure about the other four. I will have to get back with you. BTW, the 6203 bearing is metric and the ID of the bearing or the OD of the bushing is 17 mm, not 5/8. 5/8 is just slightly smaller than 17 mm, so a 5/8 bolt will easily go through a 6203 bearing.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 12-25-2014, 10:00 AM
Bob95065 Bob95065 is offline
Did anything happen with this? Put me down for (2) pulleys if you are planning on making any.
Old 12-25-2014, 11:06 AM
gdheck's Avatar
gdheck gdheck is offline
Just found this discussion. Put me down for a pair of pulleys.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 12-25-2014, 12:10 PM
These will work.correct part #for a tiller.
http://www.ebay.com/itm/New-V-IDLER-...item3ce637a6ea
Up to 534 and counting...
Old 12-25-2014, 02:12 PM
I thought the OP was going to have sets machined that take the replaceable bearing? That's what I would like to get.
Old 12-25-2014, 08:23 PM
gdheck's Avatar
I was looking for the replaceable bearing style too.
Tags
mule drive, pulley, tiller
