#31
That's very good info. Same exact part in a different package, without MTD's excessive tariff added to it.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811 |
#32
Yeah, I was pleasantly surprised when I pulled them out. Fresh sand blasted and painted wheels, USA bearings, and a pair of V61's will make a man happy!
#33
32 posts about wheel bearings, seriously? You lookup the part # then Google Cub Cadet what ever the part number is, end of problem.
#34
![]() Have at it Farmall, I honestly don't care. I'm 71 years old and I know how to lookup parts and find the best bang for the $$$. Sorry if I "Offended You" LMAO
Why Farm Half When You Can Farmall? 1282 | 44C Deck, 42" Blade, 020" Over K301 * 1711 | 50C Deck, #1 Rototiller w/ Extensions, Sleeve Hitch, CH18S * 1811 | 46 GT Deck, 42" Blade, M18, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck * 1914 | 44C Deck, KT17 Series II * 127 * 1650 Twin Stick | 50C Deck, 42QA Snow Thrower, K341 * 1862 |
#35
There has been A LOT more useless drivel on this board, and this thread is the topic of criticism.. slow day?
#36
#37
Who has the best price? Napa online is showing 24.49.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
#38
The darkminion has the best price $20.97.
Up to 534 and counting... I give up updating my profile! |
#39
Just went to use my 149 the other day to do some food plot prep. I had to drive it about a 1/4 mile on a laneway and right away noticed the one wheel bearing was shot and I need it now as there was (should have been) a break in the rain predicted. I found some on Amazon with a two day delivery and it looked like a pack of four for $18. But reading the comments, one guy said, "... beware, this is for only one bearing...".
So being as they are probably cheap, offshore bearings, I order four. Yup, you guessed it, I got four packs of four! Anyway, I popped the inner seal off and re-greased two and installed them. Probably fine for tilling, but no way will they stand up to loader work. The bearing bores on the rims are about shot too, so I may machine a tube for some huskier bearings and weld those into the rims. |
#40
