Old 07-07-2014, 01:57 AM
I had a junky old 48" deck that I put on it and it turns out to be a pretty good grass cutter.
I like this. The ones that don't look the best sometimes work the best.
Yeah, Kinda like me... Old, Ugly and Broken Down... But I do still work pretty good.
Originally Posted by Darrell View Post
SOOOOOOOOOO , What were the electrical problems ??????
Inquiring minds want to know.
The first thing I found was that there was continuity between the S/G side post on the solenoid and the small actuator post on the solenoid, even with the wires removed. So I changed the solenoid and the issue went away. Then I kept noticing a tiny little spark on the "A" terminal of the S/G when the key was turned to the "start" position. I didn't have any new S/G post bushings with me, so I gave the post, wire and all, about a 30 degree turn and that problem went away (I'll replace the bushings the next time I'm there). After that, it would start and run fine every time I turned the key, however, I was only getting about 8.6 volts at the battery with the engine running nearly full throttle. So I took the voltage regulator out, cleaned the points and adjusted it to about 14.6 volts (it was difficult, turn the screw a tiny little bit and it would go from 13.7X to 14.6X) so I opted for the higher (yeah, I know, it's supposed to be 14.2) but after I replaced the cover it settled back to 13.92-3 v and I figured that was close enough.
It has started and ran great ever since.
I have cut our grass there and the grass at the other house there twice each plus driven ONE mile each way between the two places two times in each direction, the oil is right where it should be and still looks as clean as it did before I started.
Originally Posted by 1650noob View Post
uh mmmm I would say the 1650 was the best cub ever made...........
The 1650 would be a great machine if only the F/R lever was where it's supposed to be!
Thank you guys for all your kind words!
Old 07-07-2014, 02:24 AM
THAT is my single biggest complaint with mine... It's just "wrong" feeling...
