Old 08-30-2014, 06:46 AM
jeepchicken5000's Avatar
thanks guys I think im gonna adjust the valves the exhaust seems a little loose gives a tap when cold then it goes away hot, need some clutch adjustments I think also shouldn't it disengage at half pedal or was that the quietlines ? I had a 122 but I cant remember my dad might though. ill be doing an oil change even though it looks like new oil, ill check the rear end fluid and does the creeper drive have a separate type of fluid it looks like it does. What do you guys use im going to probably use 10w 30 in the engine the tranny was the same right ? I can always look in my manuals I got also.
1981 cub cadet 682
1966 cub cadet 122
Old 08-30-2014, 08:02 AM
IHinIN IHinIN is offline
The clutch should be adjusted so that there is about 1/16" free play between the throwout bearing and the release arm. That keeps the bearing from spinning when the clutch is engaged.
As for engine oil, Kohler recommends straight 30W above freezing and 10w30 below. The gear drive rear ends can use 30W oil or Hytran.
Old 08-30-2014, 08:11 PM
well guys got it out in the sun for some pictures looks great will be doing the oil here soon and the clutch adjusting, I adjusted the valves and there still a tap it runs great actually better the nit did but you can still here a tap not sure what that's about. Heres some pics to look at
1981 cub cadet 682
1966 cub cadet 122
Old 08-30-2014, 08:14 PM
Did you put it back together with rusty bolts or is that my imagination?
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 08-31-2014, 06:47 PM
jcsmith jcsmith is offline
That looks sweet. One question tho, what is on the rear of the S/G? Well 2 questions really, Did you re-use hardware? I'm re-using as much of the original hardware as possible on my 104 because I like the IH stamp. I know some here say get new, but I like re-using what I can.
I know it is only original once, but I think you made the right decision on this one. Some do deserve to be left alone tho. Nice work.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 08-31-2014, 08:16 PM
I wire wheel the rusty bolts so they are clean but still have there brown luster, I use as many original bolts as well, ill be doing some touch ups cause I have some scratches here and there, I wait till its all together then paint the bolts on the tractor cause if you do it first they just end up flaking and getting scratched wjere the socket touches them and you have to repaint then anyway . the thing on the back of the S/G is a amp meter that someone rigged up, probably the old ladies husband and it works great looks pretty old I guess its better then putting a hole in the dash and I like it there cause your always looking that way when mowing or at least I do. to my last post I did adjust the clutch and it is so much nicer to drive now, only thing I don't like is my wallet digs into my leg when sitting on the seat im not really that fat lol must be the small seat.
1981 cub cadet 682
1966 cub cadet 122
Old 08-31-2014, 08:19 PM
Here is that amp meter
1981 cub cadet 682
1966 cub cadet 122
