#31
Hey..... um, I want to return to the original subject for a minute. I guess I wasn't really paying attention when I read this thread the first time. Maybe it was just a typo on your part, but in your original post you say you have a 2082 and a 451 snowblower, but that you need a 450. Is that info correct? Because if it is, you have the right blower. The 2082 needs a 451, not a 450. So....... what do you have exactly?
#32
![]() Quote:
#33
Mike, we don't call you Cubcrazy for nothin!
I didn't check the serial number break. You are correct. So...... it comes down to serial number then. ![]() |
#34
![]() Quote:
![]() Yeah, the earlier ones had the mags then they went to the commands. He needs to get a pic of the engine. |
#35
Since I am the one who started this thread, let me jump in here. I have an early serial number 2082, an it does have a Magnum. The magnums have a PTO with a small (4.5" if I remember) pulley, the later serial number 2082's have the Command engines with a 6" PTO pulley. The early tractors use the 450 blowers the later ones use the 451. The only difference is the ratio of the gearbox. I converted the 451 to a 450 by swapping the gear box. It would have been easier if I could have changed the PTO but nobody makes a PTO for a 1 1/4" shaft with a 6" pulley.
#36
![]() Quote:
#37
![]() Quote:
-Ryan
#38
Looks like I was under a false impression that the 2082 changed engines at the serial number break. I wrongly assumed when the PTO shaft changed size from 1 1/4" to 1 1/8" the engine changed too. Looks like only thing changed was the spec number of the Magnum engine. Anyone out there with a 2082 that has a serial number 821060 or higher that can verify that for me? I guess what helped to confuse me is the late 2082's share the PTO with the 2084 that has the Command engine.
#39
I checked on Parts Tree, the early 2082's have as you said an 1-1/4" crank and the later 2082 have an 1-1/8" crank.
Cub Cadet 717-3043 PTO Clutch for 1/1/4" shaft Cub Cadet 759-3303 Armature ------------------------------------------ Cub Cadet 717-3340 PTO Clutch for 1-1/8" shaft Cub Cadet 759-3646 Armature If it was me I'd call Warner and see if they can come up with a clutch like the one used on the later 2284's but with a 1-1/4" bore. The Warner series is TG2000 This is the contact info for Warner. I'd try the application assistance # Warner Electric Electromagnetic Clutches and Brakes New Hartford, CT - USA 1-800-825-6544 For application assistance: 1-800-825-9050
