Old 10-02-2014, 04:13 PM
Originally Posted by dvogtvpe View Post
torque the brass nut? I've never done that before. I just use common sense tight.
I didn't know it had a torque..... Shouldn't be surprised. Everything does.....
Old 10-02-2014, 07:59 PM
OldCubby OldCubby is offline
The governor is fixed and worked like a charm! the tab did need to be pointed down when installed and then I went through the procedure to set it.
Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978
Columbia City, Indiana
Old 10-02-2014, 09:18 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
years ago I helped write a manual for a military truck (PLS) they built. I did the engine section. when ever they asked what the torque is on a bracket or a cover I'd say common sense tight. their response was always "We assume their is no common sense in the military"
realistically there's only 2 things you need to torque, rod and head. the rest are tight enough you don't strip them out and tight enough they don't come loose , I've been turning wrench's since I was 10.
Old 10-02-2014, 09:21 PM
dvogtvpe's Avatar
Originally Posted by OldCubby View Post
The manual calls out 100/120 in-lbs of torque for the bushing nut. I guess I use common sense if I read the manual
If I followed the Kohler manual I wouldn't be making the horsepower we are
Old 10-02-2014, 09:22 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
I do intakes too. Especially aluminum.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-02-2014, 09:23 PM
I think he was referring to the "K" series Kohlers ......
Old 10-02-2014, 09:24 PM
dvogtvpe's Avatar
I was referring to Kohler.
Old 10-02-2014, 09:26 PM
Shrewcub's Avatar
That occurred to me the second I hit I hit submit.
Sorry, Don!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 10-03-2014, 05:51 AM
GOOD to hear.
Old 10-03-2014, 07:39 AM
dbuck dbuck is offline
Thumbs up
Glad to hear you have the gov'r problem straighten out. How is everything else working out on your newly restored 1250?
Don B, USAF 1962-1968, Ft. Wayne, IN
