Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 01-25-2015, 08:59 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Welll, I got it. Got it home and tried to start it. It has a mechanical fuel pump that I don't think works, rusty water in the fuel lines and the freaking injectors were loose. I put new fuel lines on it, borrowed an electric pump off of another machine and hooked up all the electrical stuff needed....no go. I know you're not supposed to touch the injectors but they were loose so somebody already messed around with them so I pulled them out(fuel was leaking from one) and blew them clean with air(prolly not supposed to do that either) and put them back in tight. I cranked it, cranked it and cranked it...won't start. Cracked open a beer, took a break and loosened the lines on top of the injectors to purge any air out and snugged them back up. Cranked it again and it runs, it runs good with no smoke and has great response on the throttle. BINGO! I then did the snoopy dance!
Good deal and good job, Todd! Proof beer fixes everything!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-25-2015, 10:24 PM
red56turbo's Avatar
Heck ya!
Todd,
Congrats on the pickup. Glad to hear you got it running, too. Sounds like you snagged a great deal. Sweet!
Josh
Diesel Cub Cadets...........
Old 01-25-2015, 10:28 PM
Tacosteelersman's Avatar
Tacosteelersman Tacosteelersman is offline
Glad you got er up n running and it worked out for you. Congrats.
3 original cubs
1512 diesel
Ingersoll 3012
John deere 855
Old 01-26-2015, 07:27 AM
No video of you doing the Snoopy Dance? I would have paid to see that.
Glad you got it and glad it runs.
Old 01-30-2015, 11:24 PM
greaseburner greaseburner is offline
A D722 will fit directly in place of a D600 or a D640. Mount holes, flywheel, gear case cover, front crank pulley are all the same. Only difference may be oil filter location side to side on gear case cover, depending what its prior use was.
