Old 01-25-2016, 10:46 PM
budscub's Avatar
budscub budscub is offline
Default jumped with screw driver
So your motor did not turn when you jumped the two big post together? you had better check that the wire going to the starter. It is broken or not corrected to the right place.
BTW; When you jump the big post it doesn t matter if the key is on or off as far as the motor turning over. It will not start with the key off but it should still turn over.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 01-25-2016, 10:49 PM
adamo adamo is offline
I have checked that wire. When I turn the key, I can confirm that I am getting 12v to the A terminal on the starter Generator.
Old 01-25-2016, 10:56 PM
budscub's Avatar
Default you are getting 12v
Okay so you are getting 12v to that terminal when you hit the key to start position.
For now lets disregard that, When you jumped the big post together you should also still get 12v to the Terminal on the starter gen. Now the thing is, one strand of wire in that cable will carry 12v, but that does not mean you are getting enough amperage to spin the starter. If you have a heavy gauge wire available, make up a temporary wire to replace it. That is what I was talking about doing with your booster cable but it may be difficult to get the cables in there.
I really couldn't see how your solenoid is wired. I could not see a wire on the big post that is nearer in the picture.
Gary
1969 125 42"
Old 01-25-2016, 11:48 PM
On a large load like a starter, if only one strand was carrying any voltage, you would read 0 volts at the starter because would consume it.
No way the wire is getting 12V on it. Something is missing
I would like to know that as well. To me, it doesn't look wire correctly.
That solenoid is the wrong one.
Also, right next to the solenoid is the PTO safety switch, which doesn't appear to have anything touching the button, and the wires are connected to the switch. So..... that likely isn't working either. I think the system is wired all wrong.
Old 01-25-2016, 11:55 PM
Also, right next to the solenoid is the PTO safety switch, which has nothing touching the button, and the wires are connected. So..... that can't be working either. I think the system is wired all wrong.
I have the old (er) solenoid, (pictured) which I can throw back on. I only purchased another to eliminate that possibility. I think the old one must be functional still. As for photos I will get better ones tomorrow and post. As for the PTO switch, it seems that it is in contact with the bar that connects to the PTO arm. I will try to get better pics of that tomorrow as well.
Old 01-26-2016, 11:04 AM
TheSaturnV's Avatar
• Even though the battery is new, you might need to charge it back up and have it load tested. The shortcut around that is to try to jump the Cub with a truck or car. It's possible to have faulty batteries right off the shelf.
• The starter/gen may be spinning, but does it have enough UMPH© to actually crank the motor over? I've got 2 starter/gens that really struggle.
I've had tractors go click-click-click and it turned out to be something like loose battery cables or juuust not enough electrical power to get the motor cranked over. Don't let your wife ever talk you into getting rid of your grandfather's Cub. That man walked out of the Ardennes alive, she can put up with a few gremlins!
Old 01-26-2016, 03:31 PM
Default New photos.
I uploaded more photos. Again, as currently wired, the tractor ran fine 2 weeks ago. However, I'm open to any suggestion. I can tell that the frayed wire coming off the solenoid and back near the voltage regulator is not connected to the voltage regulator. The only available terminal is the L terminal. I disconnected that wire and tried again, still just a click.
Old 01-26-2016, 05:35 PM
Post a pic of you battery.
Old 01-26-2016, 07:58 PM
You do have a 12 v battery, correct?
Old 01-26-2016, 07:59 PM
I do.....
Tags
129, electrical probs, no crank
