Old 11-28-2016, 10:39 PM
You need to crank that baby all the way up. Speed up the wire for sure. Should sound like bacon frying, only without the pops. Just a constant sizzle.
That wire is correct if you are not using shield gas.
Old 11-29-2016, 04:17 AM
Todd I'm not familiar with the cricket but a couple things to look for and or maybe change. You're using flux core wire so make sure the polarity inside the welder is set correctly. It will tell you how to hook the two cables up internally, straight polarity versus reverse polarity. You need to use straight polarity for flux core wire, it does make a differences and is sometimes overlooked.
Make sure the wire rollers and tension on them inside are correct because it's adjustable. Flux core wire is softer and if the feed rollers are slipping on the wire it won't be fast enough or consistently coming out and giving that surge of wire at times and sometimes not.
Also the feed wheels are specific to wire size and are most of the time able to be swapped around and are stamped for it as well As on the tip. I personally use a .030" wire on my smaller machine, but also use shielding gas. I'm not a fan of the flux core wire because of the spatter and mess it makes leaving the slag. Is your machine capable of using gas? If it is I would get a small tank and switch.
Technique of course matters a lot but making sure the machine is set up right first is equally important.
Old 11-29-2016, 06:38 AM
Jon, I will do a little practice welding next time.
Alvy, I think I checked the polarity the last time I used it but I will double check it again. I didn't look at the rollers or check the tension either and now that you say that I don't think the wire is feeding consistently. I will check that too.
This machine came to me from a mechanical contractor that owed us money so there is no telling how much use it had or any maintenance had been done to it.
Old 12-25-2016, 06:09 PM
Well, it was 71* here today so I figured I would spray some 935 white paint on my crappily welded wheels. 71* on Christmas, what's that all about? This project is taking forever to get done.
Old 12-25-2016, 08:05 PM
dag1450 dag1450 is offline
Looking good Todd and that will b a sweet tractor! I have like 10 things waiting for 935. Its so frustrating when life gets in the way of Cubs...lol.
Side note...I found another NOS 385 mule drive. Not sure why i bought but....ya know...had too!
Old 12-25-2016, 11:34 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Attachment 80955 Attachment 80956 Attachment 80957
Looks good Todd,... same weather here today... I really wanted to do cub stuff today but you know the family calls! But it is Christmas so I guess they win this time!
Jay
Proud owner of the following:
Old 02-18-2017, 07:02 PM
Still swinging at this 982. Wow, I started this one over a year ago. I just didn't have the time to stay on it like I wanted to.
I'm trying to save the original paint as much as I can but the floorboards had a good bit or rust on them so they got bead blasted and painted. I hope I can blend the old paint in with the new.
Old 02-18-2017, 07:14 PM
Gonna stack some weights on this one.
Old 02-18-2017, 07:51 PM
john hall's Avatar
Either you were painting weights for inventory, or you have something unmerciful planned for this Cadet
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-18-2017, 09:50 PM
jaynjeep's Avatar
Looking good Todd!!
Doubt you will have any traction issues if you use all those weights!!
Jay
